My Bosch 2400E tankless water heater will ignite but immediately go back off. At first it worked but then built up condensate in the chamber. After drying it out and putting it back together it hasn't worked for a week. At first I failed to install the drain hose on the outlet side which probably caused the condensate problem. That has been remidied. The reason for not hooking up the drain on the main exhaust was because I used a vertical vent kit which has a drain on it. HELP Me Please.
  • mdingus2 Jan 10, 2009
    My Bosch 2400E is natural gas. Everything at this point is by Bosch's installation instructions.
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
do you have any codes that come across the screen?
tom
Posted on Jan 10, 2009
  • Thomas Jan 10, 2009
    you mentioned that you did everything according to the instructions, which tells me that you have the oringinal manual for the heater. to me it sounds like you have what they call "no flame ionization". and that you can read on how to remedy from looking on page 39 top of the page.
    tom
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
We installed a Bosch 1600h ng tankless and it will occasionally ignite but not regularly??
Before calling service technician, open following links for Bosch troubleshoot resources:
1) General resources:
2) Sales page: Notice the paradoxical promotion of unlimited hot water that saves 50% off utility bill.
http://www.boschhotwater.com/BoschHotWatercomHome/GasProducts/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
3) 1600H troubleshooting. Click each item and it opens drop down menu that also has links to service bulletins. Lots of reading, but a great way to get familiar with your product.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
I do not recommend tankless for the number of difficult and expensive problems, the required yearly maintenance, plus the specific need for incoming air quality, sufficient quantity of gas, water quality, water pressure, water volume, and correct venting and drainage of vent condensation. And never recommend self-installation since most tankless manufacturers refer immediate problems back to the installer.
Assuming the tankless was installed correctly and not defective:
Other problems can be caused by household conditions.
For example crossover:
http://waterheatertimer.org/Crossover.html
Tight house: tankless require more incoming air than tank-type because they burn so much more fuel per minute of operation:
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Low water pressure:
http://waterheatertimer.org/Low-hot-water-pressure.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Can you change the bosch 2400e lp over to n gas
See the distributor ,they should be able to supply the required regulator.
I have an earlier model Bosch tankless water heater. my instruction says mine can.
I would assume that yours should be also.
Good Luck.
Mar 12, 2011 | Bosch AquaStar 2400ES-NG
Bosch 2400E-NG output temp fluctuates
This is a great heater. It is however crucial that it be installed to every detail of the manual. If there is trouble send pictures to Bosch tankless you can call 1-800-283-3787 ask for Bosch Tech support or go to boschhotwater.com click find a contractor and call the closest Bosch Service Provider most will travel.
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Bosch Aquastar 2400E LP Does Not Heat Water
Sounds like the water flow sensor and servo, may just need cleaning, get it checked out by a Bosch agent
Nov 10, 2009 | Bosch AquaStar 2400ES-NG
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
