Question about Kenwood KAC-8104D Car Audio Amplifier
My kenwood KAC-8104D power light wont turn on but the blue illumination light powers on?
lostinfamily
  • 149 Answers
SOURCE: Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Posted on Mar 16, 2009
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
  • 6 Answers
SOURCE: What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
Posted on May 29, 2009
smarthome2
  • 1114 Answers
SOURCE: I have the kenwood kac-8104d amp and it lights up
Check your RCA's from the amp to the deck, make sure it's on an output not an input on an aftermarket deck,and the input, not the pass thru on the amp. If you have it hooked up to a factory deck, you've opened a whole new can of worms! If its a factory Deck; Post the make and model of the unit if you can find it, as well as the vehicle year make and model. I get as much info as I can on it and walk you thru the details. If it's aftermarket and you've checked the above, post the make and model of the deck and I'll do the same. Hope this helps
Posted on Jun 24, 2009
housejess
  • 317 Answers
SOURCE: amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Posted on Nov 07, 2009
The amp.
check power fuse make sure it's not blown and gettin proper 12 volts if all connections are properly fixed maybe get it checked out
Jun 06, 2010 | Kenwood KAC-8104D Car Audio Amplifier
KAC-8104D Car Audio Amplifier: Fuse keeps blowing why...
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
May 16, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Amp is not operating at full potential also red portectant lite comes on kenwood kac-8104d
make sure all your wires you are using to connect the amp are 4 gauge check your ground make sure its drilled threw thick metal scuff off the paint that its grounded too and check how you have your subs wired see what ohm there wired in the you can get more power out the amp in 2 ohm then 4 ohm
Mar 31, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Amp lights up, but no power to outputs.
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
I have the kenwood kac-8104d amp and it lights up and everything, but it doesnt power my subs hooked up to it. I have no idea why because theres power going through andd the amp is turning on. Any help?
Jun 23, 2009 | Kenwood KAC-8104D Car Audio Amplifier
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Amp wont turn on
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
20 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
