Question about Wega Mininova EPU Espresso Machine
Pump problem i have a wega EPU 1 .. the pump is since 1999 i used twice a day suddenly i have a pump problem .. weak pressure should i change the pump?
    President:
  • 1,618 Answers
Do you have a manometer on the machine and if yes, what is the reading when you are pulling a shot, does the gauge move, have you opened the side of the machine to see if the pump is turning, you might have to adjust the pressure on the pump by using the adjusting nut instead of replacing the whole thing.
Posted on Mar 26, 2009
My car stops suddenly and after few minutes it starts and works normally.At the beginning it was doing this around once a month,then every few days ,lately almost every day,now many times every day.
Sounds like fuel pump is ready to fail. First do the easy stuff. Change out fuel filter. If that improves then you are good to go. Secondly I would do a fuel pressure test this test will tell you if the fuel pump is weak and or about to fail. Good luck
Apr 02, 2015 | 2004 Ford Explorer Eddie Bauer
Water coming slow
filter plugged or pressure weak.
Dec 17, 2013 | Wega Coffee Makers & Espresso Machines
Im looking to source a wega Mininova espresso machine in SA?
Wega is good, generally, but avoid this Mininova. Tell me if you are looking to a home machine, or for commercial use. Either way, it proved unsuitable. We gave many Mininovas to scrap dealers, having made the mistake of damaging our reputation by promoting them.
Nov 12, 2013 | Wega Mininova EPU Espresso Machine
Need replacement steam wand wega epu 2
wega epu. Commercial machine. I'd check espressoparts.com. Any faema, wega, nouva simonelli wand will screw into the wega valve.
They also have precision wands from japan. Sproline series i believe it is called.
I have no association with the site but i do know that any of the parts Listed will work.
Oct 04, 2013 | Wega Coffee Makers & Espresso Machines
Wega espresso
Steam out of the top is a bad safety valve.
Steam out of wands when they're off is bad gaskets in the valves which usually means they need to be rebuilt.
Steam out of groups is a water blockage and/or pressure stat is going bad and causing the machine to over heat.
Can be any one of the following. Need more information to answer properly.
May 02, 2013 | Wega Mininova EPU Espresso Machine
Wega Espresso Machine is slow to recover steam pressure
Bad pressurestat or bad heating element. PS feeds power to heating element, heating the machine til its up to pressure, which then turns the pressure stat off. If either of the two pieces are bad neither will work properly.
Could also be the machine is overfilled which causes the machine to take longer to heat up.
Sep 20, 2011 | Wega Mininova EPU Espresso Machine
Can you damage the solenoid on a commercial wega by back flushing for 10 seconds? I have been told by the repair man that the reason our solonoid busted is because we are back flushing too much. We only...
No you cannot damage a solenoid in 10 seconds, if so then the advice that I give to all my customers who never have a problem is wrong. Have him check the pump pressure that might be set over 9 bars and or the expansion valve is not working. Here is a copy of the backwash page that I give to my customers:
Apr 16, 2010 | Wega Mininova EPU Espresso Machine
Wega Atlas where is the boiler reset switch
Usually on the left side of the boiler just above the element, follow the wires from the element unitl you get to the red reset switch.
Jan 29, 2010 | Wega Mininova EPU Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Wega Mininova EPU Espresso Machine Logo
188 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
