Question about Bissell ProHeat Pet Upright Deep Cleaner, Purple, 89104
Had to take bissell 8910 completely apart, need reassemble instructions
Had to do some really stinky carpet cleaning with the deep cleaner. when finished i had to take the machine completely apart to clean it. It was so pungent, i took every hose off also.Now I need help putting it back together.
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
Junoon007
  • 1011 Answers
SOURCE: bissell carpet shampooer
Dear Sir/Madam,
- Remove the tool from the end of the hose and see if the hose will spray. If there is spray with the tool removed, the tool is clogged. Clean out the spray tip of the tool with a safety pin or paper clip.
- Stretch the hose out and give it a few light tugs to release any kinks in the internal water supply hose.
If there is still no spray through the hose, please take your machine to a local BISSELL Authorized Service Center. To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com under the Customer Center tab near the top of the homepage. Enter your zip code in the Service Center box on the right of the page to perform your search.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 20, 2008
SOURCE: Reassambly bissell 8910
I am in the same situation with my 8910 if you get an answer will you let me know my email is codeman750@msn.com
Posted on Sep 28, 2009
tooltech75
  • 80 Answers
SOURCE: bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Posted on Oct 08, 2009
James30096
  • 6 Answers
SOURCE: need pics of bissel hose assembly
Just what the doctor ordered:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This is not my website, you should thank the guy that made this. It took me a few days of searching to find it.
Posted on Nov 18, 2009
I NEED TO CLEAN FILTER
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Dec 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat 2x manual
Sep 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Manual for a Bissel pro heat
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Requireuser manual for bissell turbo upright carpet steam vacuum cleaner
Hi Cynthia: I believe your model number is the 8910W. User Guides for the 8910 Series are available online. I am including links to two versions currently available:
http://canada.bissell.com/images/UserGuides/8910.pdf
or
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0406059.pdf
There does note seem to be a User's Guide available specific to the 8910W. If the 8910 Series User's Guide is not helpful for your model, please reply confirming your model number and will try again.
Thank you for using FixYa!
Jan 15, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
How to use the bissell proheat Carpet cleaner 8910
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jan 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ProHeat Pet Upright Deep Cleaner, Purple, 89104 Logo
27 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
