Question about Garden
MY PROBLEM IS WITH A TROY-BILT 7524 SNOWTHROWER THAT WILL NOT START, IT DID NOT START FOR 18 MONTHS---CHANGED THE PLUG--NOTHING, PLEASE GIVE ME ADVISE.
THE GAS HAS NOT BEEN CHANGED--ADDED STAY-BIL
  • Garden Master
  • 2,478 Answers
Change the gas.
Posted on Nov 28, 2012
  • 10865 Answers
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
Posted on May 06, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
  • 41 Answers
SOURCE: My Troy Bilt Self Prop. Z-start won't keep running...
There may be a cracked fuel line, cracked primer bulb, loose carburator, dirt/trash in the carb....it sounds like a fuel supply problem. Hard to tell with out hands on.
Posted on Aug 02, 2009
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
Not getting spark troy bilt snow blower model 7524
1st disconnect the auger /drive safety kill switch wire , see if it starts ? no? then it's most likely a bad ign modual or ign coil yes? then look at auger/drive control handle , i bet the spring broke and its not moving all the way up to disengauge the auger or drive
reconnect safety wire before using machine
Feb 23, 2015 | Garden
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
How do we get a troy-bilt operators manual for a snowthrower model #31AH63N2711
need a replacement manual for a troy bilt generator 5500 watts
Dec 26, 2009 | Garden
My Troy-bilt Storm 7524 snow blower goes off after 10min running
it sounds like it may be you armeture[coil], it heats up and stops.
Dec 11, 2009 | Garden
I have a Troy Bilt Bronco, Kohler 18 engine
its the coil it has the same one as a 12.5 has
Sep 18, 2009 | Garden
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
