Question about Panasonic Workio DP-3530 Copier
Scanner sittings - Panasonic Workio DP-3530 Copier
  • dcannon898 May 11, 2010
    Can you be more specific, please.
  • 100 Answers
Yep!
by default, for dp-3530 the scanner key is not included. it an option that you still need to purchase
Posted on Mar 23, 2010
I have 3 scanners in need of repair. 2 do not scan no red light. 1 doesn't sit in the cradle you have to push down on it.
Please contact Barcode Trading Post for repair of your barcode scanners at 888-317-3440. We have free evaluations and quick turn around on repairs.
Why Choose BCTP Our focus is on Service and Support
Mar 17, 2016 | Computers & Internet
Lab top says can not find the scanner , i have installed the cd , went through the steps it is in the c drive but it can not find it
Try Updating USB drivers for PC if usb connection on scanner
check device manager as a previous scanner may be sitting in ther scanner list and remove it and try again to get windows to detect it.
Apr 17, 2014 | Acer Scan to Web 3300U Flatbed Scanner
Cant open scanner features on my ricoh 1232c
Did you let the copier sit for a couple of minutes? Sometimes when you turn the copier on it won't let you get into the printer or scanner features for several minutes, for no apparent reason. Letting it sit and coming back a few minutes later usually works.
If not, and you still can't get in, the print/scan software may be bad. Turn the copier off and reseat everything -- DIMMs, hard drive, SD card -- everything you can see attached to the controller board (the main circuit board). Even unplug and reattach the connectors.
When you reboot the copier, it should work fine. (Remember to give it a couple of minutes before trying to get into the scanner features.)
If you still can't get in, try to isolate the problem. Can you access the scanner screen on the copier by pressing the "scanner" button? Can you get into printer features?
Nov 18, 2009 | Ricoh Aficio 1232C Color Copier
Solution for "c30 code on Mita DC 1255
A C30 code is as follows straight from the Tech Manual.
.Timing switch fails to turn ON 2.5
sec after scanner motor starts to
turn in normal direction.
.Home position switch fails to turn
ON 6 sec after scanner motor
starts to reverse.
Solutions:
.Defective scanner motor
.Defective timing switch
.Defective home position
switch
Also check the scanner rail some of the seals on the rail around were the motor sits turn to gunk and will stop the scanner assy from moving.
Jul 01, 2009 | Kyocera Mita FS-C5016N Printer
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
Driver for Nikon LS 100 35 mm film scanner
do one thing i send you a link in that you download the driver and software after that you can work http://www.gfdi.fsu.edu/staticpages/index.php?page=nikonls1000
Jun 03, 2008 | Office Equipment & Supplies
Cr-180 Won't Detect Checks
Embarassingly enough, a reboot took care of the issue! Duh.....
Apr 04, 2008 | Canon CR-55 Pass-Through Scanner
Vibration and Scanner Error Message
Have you cleaned and lubricated the scanner rail and the pad where it slides across.
Sometimes those rails become dry and get dirty.
Also if you can, reseat all the connectors to the scanner. That would require taking the covers off the machine, You may have a bad connection on one of the scanner cables.
Lastly the motor itself may be bad. But drag or a bad connection seems more likely to be the problem.
Feb 23, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Panasonic Workio DP-3530 Copier Logo
102 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
