Question about Sharp Refrigerators
My refrigerator's evaporator partially frozen. why?
The refrigerator is 20 years old.
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
Most of this problem with Freezer fuse.
Posted on Mar 03, 2015
3 Suggested Answers
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
Frozen compressor
A frozen compressor can be caused by several things. One cause could be partial loss of refrigerant or being over charged by someone adding to the factory charge. Another cause for a frozen compressor might be poor heat transfer in the evaporator, which is where the cool air comes from. This is usually systematic of a dirty evaporator or poor air flow coming from the fan. Another cause for a frozen compressor is the system not turning off when it should. This problem is usually a result of a bad thermostat or the thermostat not turning off soon enough.
JohnL
Apr 19, 2016 | Dometic Rooftop RV Air Conditioner
Defrost Problem - evaporator completely frozen
i know i think in the fridge part (atleast on mine) there is a knob for temp.
if that doesnt work i guess you need another defrost terminator
Dec 13, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Doesn't cool
Hi, Yes, If the evaporator was not frozen over then I agree with you. The unit has lost its refrigerant charge. The only thing you can do is to have a licensed refrigeration man find the leak, repair it and recharge it or replace the refrigerator. If the evaporator is frozen over the defrost timer would be the problem. In this case, manually defrost it and it will be good for a few days until you get it replaced. kstfas
Sep 27, 2007 | Viking VCSB483 Side by Side Refrigerator
The freezer part of the fridge used to work so well n ice would form in a few minutes of switcfhing on the fridge. but now, ice rarely forms and ice cream simply melts. what could be the prob
Cause of that problem is a clogged in the tubing system, if your refrigerator is 5-10 years old it is a candidate for that problem. But if the refrigerator is newer, few years old then be sure the evaporator has no small hole or punctured cause by sharp object when removing frozen thing on it. Inspect it visually if you haven't found hole in evaporator then a system is clogged.
Thanks for asking.
Sep 01, 2011 | Refrigerators
It keeps running and doesn't shut down. Freezer
Check condensor for clogged coils and make sure the back is on it. (The pasteboard covering over the Service Opening on Bottom Rear)
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Whirlpool Refrigerators
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
I have a 20 year old sub-zero refrigerator. For the last two weeks the refrigerator is so cold that everything is freezing. If I turn down the thermostat the freezer warms up.
It sounds like the freezer side is losing its capacity......All cooling done on the refrigerator side is done by air flow of the fan in the freezer compartment by the evaporator coils(aluminum fins looks like a radiator)
You might want to pull the back panel of the freezer section and look at it.
Normally it is fully frosted when running(whitish snow covering on evaporator) If it is only partially frosted it has a freon leak or compressor problem. If it is engulfed in frost and there is no air flow possible through it your defrost system has failed.My guess is it is partially frosted and you have a freon leak.
Also check the fan by the compressor is running on the outside and the condensor coils on the outside on the bottom are clean.( fan runs when compressor runs)
A
Jan 14, 2010 | Frigidaire FRS266ZDSB Side by Side...
FRIGIDAIRE frost free refrigerator seems to be leaking. Items in freezer are frozen...items in refrigerator are cold...any ideas? It has an ice maker which is working. Approx. 13 years old.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 28, 2009 | Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
