Question about Logitech Z623
How do I disassemble a Logitech Z623 speaker system?
Specifically, I am having difficulty removing the power/volume/bass knob circuit board.
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I have just bought
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Posted on Aug 08, 2011
I plugged my Logitech Z623 (110V) into a 220V output. Made a 'pop' noise and now it doesn't work. What parts need replacing and how would I do this?
Take unit apart an look at power supply. It could be just the solid state fuse popped. Power supplys are not hared to repair, the diodes are about .50 a piece, the caps about $1 a piece or so. Hopefully ot did not reach the speaker, an i doubt it did.
Oct 12, 2014 | Logitech Z623
Logitech z623 110v burned to 220v what parts need change i need help
You have a direct short in the power board. Replace the speakers.
Mar 26, 2014 | Logitech Z623
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
Why is there no bass from my speakers when plugged into laptop?
Could be something wrong with the output from laptop.Try wiggling the jack in the connector while music is playing to see if there's any change.
May 21, 2012 | Logitech Speaker System Z623
The power turns on and off and does not any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 17, 2011 | Logitech Z623
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
hope this helps
Aug 08, 2011 | Logitech Z623
A gift was just given to me. They are the Logitech Z623 speakers. But, they came with no documentation. When I plug them in as intended with either my HDTV or my desktop pc, only one of the satellite...
I checked Logitech's website and they don;t have any downloadable documentation for this product. Anyway, let's just try and fix it.
First, make sure your left and right speakers are connected properly to the bass speaker.
Next, the wire from the bass should be connected to your soundcard's line out port (light green) or into your TV's audio lineout.
You can also adjust the volume of your bass separately on the right speaker.
Update me if this worked or if you are still having trouble.
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
Only one small speaker is working, it works from left or right outlet, bass isn't working and the other small speaker isn't working. What could be wrong
Your main board located inside the sub woofer that controls and separates the sound
has lost it's ability to switch the sound. You will either have to buy a new speaker system or call the manufacturer to see where a service center for you speaker unit is near you for repair.
This also can be a bad volume control knob either way it will need to be serviced.
Oct 08, 2010 | Logitech Z-2300 Computer Speakers
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Dec 18, 2008 | Logitech X-540 Computer Speakers
Logitech Z623 Logo
62 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
