Hi
Have a hotpoint CDT00 Condensing dryer. The indicator button telling you to empty the water from the tank has stayed on after the tank has been emptied. The dryer will work but there is no heat, hope you can help
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Plz rate my solution.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Bosch Axxis WTA 4107 Electric
Trying to replace belt on Performa Model PYE22000AYW. Spring on idler is attached to idler arm, but...
(More)
Trying to replace belt on Performa Model PYE22000AYW. Spring on idler is attached to idler arm, but other end is not attached to anything, where does it go?
I have a Braun AXXIS Dryer that I just got that is leaking water onto the floor. It does not have an...
(More)
I have a Braun AXXIS Dryer that I just got that is leaking water onto the floor. It does not have an exaust hose like my last dryer.
My dryer appears to be working fine but ther is no heat - Bosch are quoting £139 call out and...
(More)
My dryer appears to be working fine but ther is no heat - Bosch are quoting £139 call out and parts charge. Is this fixable and is £139 reasonable
My machine has stopped working. If you select a programme, the 'Drying' LED (the bottom one) starts...
(More)
My machine has stopped working. If you select a programme, the 'Drying' LED (the bottom one) starts to flash. Pushing the Start button produces nothing. Any advice would be very much appreciated.
can you please send me a wiring diagram for a WTA 2000 electric dryer via e-mail to...
(More)
can you please send me a wiring diagram for a WTA 2000 electric dryer via e-mail to johan.vanloggenberg@harmony.co.za Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
