Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
Lost manual instruction booklet / before learned basic setting
Hi!happy 2009 to you...
i am a proud owner of a neat ViewSonic VA712b, 17 in. black flat monitor.
Where can i get access to  a PdF or HTML documentation regarding the settings and maintenance of this fine piece of technology, pray teLL ?
 §ince in my usual clumsiness {or momentaneous fit of frenzy?} i probably threw it away in the recycling bin along with old newspapers or the like...
Thanks for your time , respectfully yours.
Jen Paqeut
~{:?B}-§=C¦
    New Friend:
Go to retrevo.com I just picked up a PDF of the manual. Good luck!
Posted on Jun 18, 2013
  • 535 Answers
Here is the manual of your viewsonic VA712b
Posted on Jan 10, 2009
My Viewsonic VA712B monitor is getting power, but no image. and also once power is plugged in it makes a low frequency noise almost like white noise. any ideas why im gettin no image?
You are not geting the image may be due to bad backlights inverter circuits, check the fuse in the inverter circuits.
Are you hearing the noise from the AC adapter or from inside the monitor?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 10, 2011 | ViewSonic VA712B 17" Flat Panel LCD...
Hi there, the problem that I am experiencing with my VA712B is also a BLACK SCREEN. I turn on the computer and the picture appears fine for about ONE SECOND, then turns black and I am unable to see...
It does the same on another PC?
More likely to be caps failure in the power supply section just like the VA912 (19" version) and the rest of Viewsonic as hswon in my albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Dec 24, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
My monitor keeps going black you can hear the sound but no picture only black screen
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 24, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic VA712b lost Power Supply need voltage & current
davsmith00, Did you look on rear of VA712B where the power plug enters the power JACK connector? Maybe it will only tell you who is positive and who is negative (gnd) some monitors state what is the required V & I for them on the rear labels somewhere. This will teach you not to lose your supply. Did the dog hide it under the bed? Good luck finding a replacement. There are sources on web that specialize in drop-in replacement IN-LINE switch-mode-power-supply Bricks. You can also try newark.com and mouser.com and digikey.com to see if they have something. I'm louie12fix on fixya or lmistyrel@ aim.com Bye for now.
May 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
124 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
