Question about Bernina Sewing Machines
Bernia 1030 is stuck in reverse stitch - Bernina Sewing Machines
2 Suggested Answers
  • 152 Answers
SOURCE: My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Posted on Oct 08, 2009
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
Bernina 1030: the stitch size/reverse lever no longer works.
Not sure what you mean by no tension from the top. If you mean that you cannot feel the spring action when you push the lever up into reverse, you need to take the machine in for repair.
Feb 20, 2015 | Bernina Sewing Machines
Needle won't go up and Down
Is this a Bernina machine with the needle stuck in the up position? If so, is the model something like a 930 or 1030 or similar?
I'll have a go at an answer but unless you give more information than this, it's not worth attempting.
Oct 17, 2014 | Sewing Machines
Singer sewing machine 1030 feed dog will not pull material in
try using maximum stitch length, if still not working try removing needle plate and clean you teeth
Feb 18, 2014 | Sewing Machines
Bernia 730 record stitch lenght
You should have a dial that adjusts the stitch up or down to make it more narrow or lengthen the stitch. Try it on scrap fabric first until you find the stitch you wish. It will stay in that position until you want to change it.
Dec 31, 2013 | Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Model 4423 singer stuck in reverse
Solution: Turn off machine. Turn stitch dial until you hear click on each stitch shown on dial. Set to straight stitch then and set stitch width to 6. try machine again being careful to put light force on the foot pedal so your not going full throttle. This is how I "de-confused" my Singer Heavy Duty 4423 when it got stuck on reverse. Hope this helps!
Jimmy
Mar 20, 2012 | Singer Sewing Machines
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
