Question about Oster 6329 2-Slice Toaster
Doesn't lock properly to toast
I have a brand new Oster 6329 out of the box and it does not lock properly to toast. Is this a malfunction or is there something I can do to properly make it toast? We have tried different electrical sockets,...but it still does not work. Thanks!
0 characters
1 Points
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
My Oster 2-slice toaster only toasts on side of the bread' do I need to replace an element ?
Are you are using the wrong slot there is one that is marked 1 slice only .
Feb 19, 2015 | Oster Toasters
Oster Tall Can Opener Ss Fpstcn1300-022
Those brands are noisy. We had one as well. Fortunately ,it did not last long when we used it. Black and decker has a good one.
Mar 01, 2013 | Oster Tall Can Opener Ss Fpstcn1300-022
The innerside elements of the toaster are not warming up. Only the outer sides of the bread slices are toasting. How to fix?
You need to take the sides off and try inspect the inner element, looking for a break in the flat wire, or a bad connection where there is an eyelet or such in the mica where the leads connect to the element. You will probably have to buy a new center element from an electrical repair outlet and replace it.
Jan 30, 2011 | Oster Toasters
Release button doesn't work, never stops toasting unless you unplug it
Hi. this is a huge fire hazard. Please unplug it and either send it to oster for a repair or toss it in the trash. The thermostat is broken and must be replaced. J.
Jul 24, 2010 | Oster 6307 / 6309 2-Slice Toaster
The lever to push down the toast will not lock in to start the toastng cycle
Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
Dec 20, 2009 | Oster 6330 4-Slice Toaster
BTA320 bought today. Lever wont stay down to toast.
Since this is brand new, I would suggest return it for a new one.
May 02, 2009 | Toasters
Trying to fix my Oster 6309 and can't seem to remove . . .
The lever actually comes off another way, turn the toaster upside down and you will see a small clip holding the handle to the metal arm inside, you can pry it off with aa small screwdriver
Nov 17, 2007 | Oster 6307 / 6309 2-Slice Toaster
Toaster Setting
There is a mini adjustable potentiometer facing the left side on the circuit board. Turning it counter clockwise to your taste.
Sep 27, 2007 | Oster 6243 2-Slice Toaster
Oster Toaster
My Oster Toaster stopped popping up after a couple of years as well - the lever just stays down until you unplug it or the toast catches on fire.
R3 was burned and replaced per the info on these discussions to no effect.
So I mapped out a rough schematic from the board and found some interesting things. Oster seems to be directly rectifying the line voltage (dangerous but cheap) through D1-D4 into 5V through DZ4 and 32V through DZ1.
These voltages seem to be across R3, which means it has 27V on 1K or about 0.73W on it continuously! Not only is this a waste of power, but it will always burn a 1/2W resistor. I would recommend replacing it with a 1W or larger and setting it up off the board to dissipate the heat into the air.
Then when toasting, the NPN transistor Q2 pulls to GND one side of the coil that holds the lever down. R3 is used as a series current limit for the 32V supply to the other side of the coil (so it has 32V or over 1W on it when toasting).
My problem with the toast not popping up was related to Q2 being blown. I don't remember the original number since I cut it out, but they seemed to have used an audio transistor with a Vce of 20V and Ic of 20mA. No wonder it blew with 32V and 32mA on it - bad design from the start.
I replaced Q2 with a cheap, commonly available 2N2222 - it has the same pinout and is good for 1A and 50V. It's been working great for months, but sadly still burning almost 1W continuously or over 6KWh per year.
Feb 28, 2007 | Oster 6329 2-Slice Toaster
Oster 6329 2-Slice Toaster Logo
57 people viewed this question
Top Oster Toasters Experts
Mike Cairns
Mike Cairns
ray gallant
Gerard McHugh
Are you an Oster Toaster Expert? Answer questions, earn points and help others
