Question about Seagate (ST3160827AS) 160 GB Hard Drive
Disk manager for seagate 160 gb sata barracuda hard disk
Please i need disk manager or other program to partition my 160 gb seagate hard disk...
shamim uddin
sbs@cyberia.net.sa
  • mustafamnr Mar 16, 2009
    virus in partition table
Windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Posted on Mar 12, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard Drive Capacity Stuck at 33.8 GB
You are probably using FAT32 for your partition on your drive: the limit for FAT32 is 32GB. Alternatively, you are using NTFS but your partition has been limited to that particular size.
You could you a Disk partition manager to change the format of your partition to NTFS or if you are already using this format extend the partion size to your requirements.
A safer alternative, if your current partition is set smaller than your drive size is to create additional primary or secondary partitions to fully utilize the available capacity: you could use (with great caution and only if you are experience) standard Windows Control Panel -> Systems and Security -> Admistrative Tools -> Computer management -> Disk management
Dec 24, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Nov 25, 2009 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Lags and says has bad sector after 14 months
Good day sir/maam, hi, 14 months is too short for a hard disk operating span, what we do is run the diskmanager software that comes with the seagate hard disk, on the diskmanager menu, run the low level format which usually removes the bad sectored space out of the way, and mark it as not usable. then may I suggest you partition your hard drive to 2, one for windows and the the other for data. call your computer dealer if they have in house techs for service, or get the copy of disk manager for your seagate. Hope this helps, thanks
Nov 04, 2009 | Seagate 750GB BARRACUDA SATA 7200 RPM 32MB...
Seagate 500gb firmware probleb
Use some partition manager to format and crate partition on your disk, use this one it´s free and very good.
http://www.easeus-software.com/download/epm.zip
Hope this help
Jun 25, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
It recognizes the new hard drive as a DVD drive
have you partitioned and formated it ? unless you do that to the drive it will not show up with a drive letter in windows. go into control panel, administrive tools, computer management, disk management - there you should see all your drives and you can partiton, format, assign or reassign drive letters to them. hope this solves your problem.
Apr 18, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate (ST3160827AS) 160 GB Hard Drive Logo
766 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
