Question about HP Pavilion dv6000z Notebook
I have the compaq f700 i have found all the drivers but 2 for xp
I need help! i need
1) NVIDIA GeForce 7000M/nForce 610M
2) Conexant High Definition Smartaudio 221 with a UAA
i have found alot of downloads but none work the HP UAA aborts when i try to install.
Thanks
  • 2 more comments
  • petterbane Jan 11, 2009
    presario F700
    s/n cnf8233819
    downgraded to xp
    i need the audio & video driver
  • petterbane Jan 14, 2009
    Thanks problem solved your a GOD.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    I see. You downgraded from Vista. That's going to be a problem. But, it doesn't mean the end of the world just yet.
    Have you used software to audit your laptop? or ever used audit software before?
    That software may reveal more exact detail. The report that's generated may be too large for a post back here. But, let me look for a day or so if you don't mind.
    All of us here run our own businesses in most cases and at any given time we are either very busy or just busy. Right now I'm on two hard deadlines. But, I can take some time later in the night like now, to do some sleuthing for you.
    Let me know if this loose timetable is OK for you or not and I'll give it a go.
    Have you downloaded and tried to install the Nvidia package with all the drivers? And, if you have, did that auto installer fail to install the Geforce 7000 M and the HD Audio?
    Regards,
    Worldvet
  • Glenn Rogers
    Please reiterate your laptop model number from HP. I can see you have a Compaq F700, but when you choose what category to put your question in you chose something different so please confirm. That will help point you go the right downloads
    I see some conflicts with what you stated you have.
    Is this the Nforce 610M chipset on your laptop? And I have never heard of a Conextant HDef Audio.
    On the bottom of your laptop should be a S/N that I can use to lookup your configuration as designed.
    Thanks,
    Worldvet
    Guru:
  • 859 Answers
Here is the link to the download package for you system for XP from Nvidia directly.
http://www.nvidia.com/object/nforce_winxp_15.24.html
Download the package and then move it to a storage location on your hard drive. Once there double click it and it will unpack there or ask you where to unpack it. Use this routine to do the unpack, don't use WinRar, etc.
Once unpacked it usually starts installing on its own, otherwise click on the Setup file. Let it run its course and restart when asked.
IMPORTANT. You should create a restore point first or back your system up, maybe both. Its up to you but be cautioned that installing this package may cause a problem. If it does, enter Windows in safe mode by pressing F8 like a piano key during bootup and then select Safe Mode and the revert back using your restore point.
I suspect everything will go fine and you will get your sound driver.
Regards,
Worldvet
Posted on Jan 12, 2009
  • Glenn Rogers
    Glenn Rogers Jan 14, 2009
    Which answer helped you more completely? For my notes? Thanks.
  • 535 Answers
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click
Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp36090 folder and select the .inf (wis30b2a)
file and click open and Continue with the onscreen instructions
Posted on Jan 10, 2009
Sir, i need cq50-21us windows xp pro sp2 driver path
Try the following drivers,
XP Drivers for CQ50-210US
NVidia Chipset,(install and reboot before other drivers), here
NVIDIA GeForce 8200
Nvidia ForceWare X 179.28 for Windows XP/2K 32bit, here
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
or you may try other versions, joint their forum for further details
Note:
If you found errors (hopefully it has been fixed) when installing Nvidia 8200M G video driver, you need to force install the driver.
Pieter's INF forgot to put hardware ID for 8200M G, see this post.
MS-UAA (required with a reboot before Audio, Modem and nForce HDMI Audio drivers), here
Conexant SmartAudio 221 (fix microphone problem by forum user) here
How to install:
Unzip to a folder.run installer.
if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect, Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver, here
nForce HDMI Audio Driver, here
.Net Framework(required before Intel Wireless and HP Quick Launch Buttons), here
HP Quick Lauch Buttons, here
If you had Intel PRO/Wireless Driver, here
If you had Atheros Wireless driver, here
or if it does not work try here
If you had Broadcom Wireless, here
Realtek usb 2.0 Card reader, here
Synaptics Touchpad Driver, here
If you had Bluetooth, here
If you had for 7 unknown devices (buttons drivers), here
Installation --> right click machine.inf, choose install.
Good luck
Oct 01, 2010 | HP Compaq Presario CQ50-210US Notebook
My Acer Aspire 5520G will not play a Blu Ray disk. It keeps telling me that I need a critical update to the Acer Archade DVD playing software. When I click on the update button it comes back with a message...
from these derived specs You do not have a blue ray drive installed in this you have a DVD drive so of course a blue ray would not play in this unit. Specs are below from acer
CPU: AMD Turion 64 X2 TL-58, 1900 MHz [(9.5 x 200), L1 cache 64 KB/core, L2 cache 512 KB/core - dual-core, 64 bit support]
Motherboard Chipset: nVidia nForce 7000M-610M (southbridge), AMD Hammer DDR 2 IMC (northbridge)
BIOS Type: Phoenix
RAM: 2048 MB [667 MHz DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)]
Video adapter: nVidia GeForce 8600M GS, 512 MB GDDR2 [128 bit, core clock 600 MHz, shader clock 1200 MHz, memory clock 700 MHz - support for DirectX 10]
Monitor: Acer CrystalBrite 15.4" LCD (LG Philips), WXGA [8 ms/220-nit, currently running at 1280x800@60Hz] - HDTV capable
Audio: Realtek ALC268 @ nVidia MCP67/68 - High Definition Audio controller; Dolby Sound; audio jacks (on the front side): headphones, microphone, S/PDIF
Networking: nVidia MCP67/68; (wireless) Atheros AR5007EG - 802.11 b/g
Storage: Hitachi - 160 GB [8 MB cache, SATA, 5400 RPM]
Optical drive: Mats hita - 2 MB cache, DVD +/- R/RW/RAM/ROM, dual layer support, CD R/RW/ROM
Card reader: Ricoh - 5-in-1: SD, MMC, MS, MS PRO, xD
Webcam: Acer Crystal Eye (Bison) - 0.3 Mpixels
Connectivity:
4 x USB 2.0,
Broadcom Bluetooth adapter,
CXT Fax/Modem - 56K, V.92,
DVI,
ExpressCard,
IEEE 1394 (FireWire),
VGA,
RJ-11 (modem),
RJ-45 (Ethernet),
CIR (Consumer Infrared),
S-video/TV-out (NTSC/PAL)
Battery: Lithium Ion, 6 cells; (initially) discharge time ~3 hours
let me know
please do leave feedback and ratings for your free answer today.
May 08, 2010 | Acer Aspire 5520-5908 Notebook
I want to listen music but xp sp 2 sound driver not found
You need a driver. Your hardware is Conexant High Definition SmartAudio 221. Just click on this HP weblink and download the driver: ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35683.exe or an alternate link: http://tc.versiontracker.com/product/redir/lid/1455592/sp37816.exeConexant%20High%20Definition%20SmartAudio%20221
May 24, 2009 | Compaq Computers & Internet
Audio driver
Compaq doesn't provide XP support for this model. Fortunately for you someone has done a lot of work to find drivers that will work.
NVIDIA GeForce 8200
Note:
How to install:
Reboot.
Good luck
The Vista Drivers are HERE
If you need any more help just let me know.
Please don't forget to rate my solution, FixYa
Thanks!
Mar 01, 2009 | HP Compaq Presario CQ50-210US Notebook
Driver Problem
Jan 28, 2009 | HP Pavilion dv2000t Notebook
Audio probon C785TU
Audio drivers for XP are not provided , see here » Microsoft Windows XP
The sound board is a Conexant AC97 try using the following driver:
Conexant High Definition Audio Driver
or
Conexant High Definition Audio Driver (for AMD)
Oct 15, 2008 | Compaq Presario 700 470024-192 Notebook
Problem with the drivers
i have hp pavillion dv 6701au laptop when i m installing my wireless driver.it is not working getting error plz help me out
Aug 26, 2008 | Computers & Internet
Audio driver for compaq presario c700 PC Note book
I have successfully installed all the XP drivers on the Compaq Presario c700 and successfully removed the bloated pig P.O.S. known as Vista.
You must download the following from Compaq's site:
Driver numbers:
sp34510 - Wireless assistant
sp33411 - Nvidia Chipset
sp33258 - Quick launch
sp35444 - Touchpad
sp36684 - Wireless LAN
sp35682 - Win Audio Bus + updates
sp33549 - Nvidia Video (Go 6150)
sp35270 - Conexant HD Audio
sp34427 - Conexant Modem
These are found all over the HP/Compaq web sites. You'll need to search for the number "sp35410", etc. Some of these are available under the driver pages for the F557US. You'll need to look under both the XP AND Vista sections!!!!
Now, the tricky part!! Listen CAREFULLY!!!! You must:
1. Install all of these drivers one by one, making sure NOT to run the sp33549 (Nvidia VIDEO), sp35270 - Conexant HD Audio, and sp34427 - Conexant Modem drivers!!!! Important! Then, reboot.
2. Run the sp33549 Nvidia Video driver file. It will FAIL! Once it has run, it will create a folder with this path: C:/swsetup/sp33549. Open the control panel, then system, then hardware, then open the device manager. Find the video controller with the yellow exclamation point. Right click, and select properties. Click the 'driver' tab at the top, and then select "update driver". Select 'not this time', then 'Install from a specific location', then select 'don't search', and then finally, select 'have disk'. Select the folder above, and that will manually install the video driver.
3. Do the exact same procedure for the sp35270 Conexant audio card, which will be in the device manager under 'PCI device'. Of course, make sure to use the C:/swsetup/35270 folder this time.
4. You can just double click the modem driver sp34427 to install it, but this must be done AFTER you manually install the Conexant audio!!!!
5. Since it took me three hours to figure all this out, you then send me an e-mail to thank me!
Vista sucks. Be happy you now have XP on this new laptop!!!!!!!
Mar 26, 2008 | Compaq Presario 700 470024-192 Notebook
Video driver installation for F733au compaq
my all drivers f733au xp vga audio modem lan wlan chip amd in this zip http://pushkarna.com/downloads/myf733auxpdrivers.zip use drivermax freeware software and import full drivers as zip or any driver from its folder (unzip firstly if folder required) and if any body have no driver on xp this is mediafire link of exe of all drivers in a zip unzip and double click after 3 days haunting I made this for me for future use http://www.mediafire.com/?jgndmweewmm
pradeep parashar
Mar 11, 2008 | Compaq Presario 700 470024-192 Notebook
F733AU
http://welcome.hp.com/country/us/en/support.html?pageDisplay=support&jumpid=in_R329_prodexp%2Fhhoslp%2Fsplit%2Fsupport
please try the above link, and try to autodetect and download the drivers
Regards
Aby
Dec 22, 2007 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv6000z Notebook Logo
482 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
