Question about Plumbing
How do I replace price pfister f-wkp-700c sprayer hose
  • 4 Answers
SOURCE: kit. sprayer/hose
watch this http://www.pricepfister.com/about/diverter.aspx
Posted on Jul 02, 2009
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
canwoodjc
  • 3301 Answers
SOURCE: Price pfister classic f-wkp-533s -
remove the handle,, Now you don't say if its the handle or the swing spout thats hard to turn, but this will work on both , (make sure the water is turned off) remove the retaining ring that holds down the ball cover sleeve, take that off and remove the either brass or plastic ball, NOTE: be sure and keep track of the direction of the slots in the ball so it goes back in the same way, some only go in one way, its those others that will give you fits ... once thats off remove the swing spout,, Now at home depot or most hardware stores they have plumbers grease, Its Kind of tacky but clear, and usually comes in a little disc , rub that on all O rings that you can see, replace any that look pinched or worn, reassemble,, your good to go !!
Posted on Jul 08, 2011
heatman101
  • 43501 Answers
SOURCE: I have a One handle Price Pfister Kitchen Faucet
The passageways in the diverter part of the faucet are very small and can get dirt stuck in them....the diverter is a plunger like piece that will slide and stop the faucet when it senses flow from the sprayer...
The only hope of cleaning this out is to do this...
Take off the supply tubes or pipes at the hot and cold supplies... then blow compressed air....a air compressor with 100 psi air and a blow gun works best...backwards through the hose and out the supply tubes....this should blow out any built up dirt in there and get the passageway open again...you also could try to open the faucet valves... take the aerator off the spout and try to blow through there also... just in case there is build up in there also...
heatman101
Posted on Jul 19, 2011
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
How do I replace the flange on the side sprayer? The sprayer and hose are intact but the part of the flange that screws broke and has to be replaced. Quesiton is where do I disconnect the hose so I can...
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
Aug 28, 2011 | Price Pfister Marielle Kitchen Faucet with...
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Need to install faucet
there need to be 3 coming off tap hot cold and infeed to pull out counter wieght about half way on pull out use plumbing tape thank you for useing fixya
Feb 22, 2009 | Price Pfister 18 Series Polished Chrome...
Price Pfister kitchen faucet two handle with gooseneck and pull down spray. The pull down sprayer will not stay up in the goosneck.
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Feb 19, 2009 | Price Pfister Plumbing
Plumbing Logo
171 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
