Question about Ridgid 26638 Saw R3121 Orbital Jigsaw
Have a Ridgid r3121 jigsaw ..can't get the blade in straight,,only used a couple of times ...supplied'T' blade ....worked great first couple of times..ideas?
Blade won't install straight
2 Suggested Answers
SOURCE: I have a rigid r3121
I was having the same problem and when I downloaded the manual, I realized I was using a U shank blade and the saw is designed for the T shank blade -- unlike the current Rigid model on display at the store that takes both! I bought T shank blades and they fit. Haven't cut with it yet, but it looks to be just fine.
Posted on Nov 19, 2011
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Husquvarna won't cut straight replaced bar
What model Husqvarna are we talking about?
Feb 03, 2013 | Garden
Blade is not straight is thier an ajustment
What do you mean? Is the blade itself is not straight when you install it or the blade is not cutting straight?
Jan 07, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
The blade guard will not raise on its own as i pull the saw down . did it all of a sudden and i found a small screw that may have fallen out somehwere.. i do not see anywhere it would possibly go.. was...
Not knowing what make or model miter saw you have here's how most of them work. There should be a long arm, about half straight and half having a lazy 'S' shape to it going from the base near where the upper head pivots up to the blade guard. It should be attached to the base with a shoulder screw so it is free to pivot. The shoulder screw in the blade guard (it may or may not have a bearing on it) passes through an elongated hole in the lazy 'S" end of the arm. Somewhere about half way down the arm there should be a screw through a bearing or bushing in the upper metal housing that rides on top of the arm. As the head is lowered for a cut the mid-point bearing pushes the arm down and pulls the blade guard up. If any of these three screws fell out, the system won't work.
Feb 03, 2012 | Saws
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
My 32" Hampton Bay Minute
Sounds like an excellent idea. In case you don't get a certain reply, i suggest that you remove a blade from your old fan and take it with you to a store that has one on display. Check the spacing of the holes, and the number of blades. You might also find that the width of the blades and their pitch (which is determined by the bracket the blades are attached to) work out in combination to give you about the same performance. But if the bigger fan has a much flatter pitch, you might find it won't deliver as much air as your old fan did with the old blades. Good luck, Al K
Jul 26, 2011 | Hampton Bay 40106 Minute II Ceiling Fan
Setting up a jig saw to cut a straight 1/4 inch
You will need two C clamps and a straight edge,I use a metal yard stick.Whatever you use look down the edge a make sure it's true.
Set up on the line and make sure the blade is going to cut on the waste side of the line.Measure the distance from the edge of the wood to the other side of the jigsaw glide plate and make a mark.Transfer the measurement to the other end.I move the blade up just above the surface so I can set the jig saw on the wood while I get the measurements.The last step is to clamp the straight edge down.Make sure to have the clamps with the handles down.Check under to make sure you won't run into any thing and do a dry run to check for cord hang ups.This is the best way as long as you keep the edge of the bottom jig saw plate against the straight edge.^^^^ Well that's how I do it. good luck
You can all so use the T bar attachment that slides through the bottom plate and clamps down with thumb screws.Personally I like the straight edge.
May 10, 2011 | Skil 94500 Jig Saw Rip Fence
Ridgid 26638 Saw R3121 Orbital Jigsaw Logo
143 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
