My mpac140 mistral split system when put on cool keeps cutting out with a p2 error saying water full but its not full . am i able to disconnect that sensor to stop this happening?
2 Suggested Answers
  • 659 Answers
SOURCE: need instruction manual for mistral mpac140
They do not have a downloadable manual that I could find but I have included their contact info so you can contact them directly. They may be able to get you the info you are requesting.
http://www.mistral.com.au/contact_us/contact_us.asp
Posted on Apr 02, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Need to know what error 6 on a minstrel air conditioner unit.Also can you scan and email me the manual for a Chunghop K 1028E 1000 1 Uinverisal remote. Thanks Gwenda
Hope this helps
error code is the fan in the head unit (indoor part) of the split system. After rining around for hours this morning - the number to get parts Mistral Bellini & Ringroup. 1300 373 199 They are based in Melbourne.
Apr 03, 2017 | Heating & Cooling
LG LP0910WNR portable Air Conditioner error code P2 and shut down
P2 is a water tray full error. I had error once, and it had me puzzled because I have a tube from the back, and unit elevated. It was producing water out the back, so it was clearly draining.
Called LG (very prompt service, no wait times at all).
The girl said that error was water tray, I still didn't believe her.
So I pulled unit from location, and tipped at a good angle.
Sure enough, less that a cup of water drained, and now it works fine.
Jul 07, 2011 | Heating & Cooling
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
Low refrigerant?
never of you have no leak but if every thing is working and it is not cooling them you may need to do that...
Nov 08, 2009 | LG Art Cool LA1000PR Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Need instruction manual for mistral mpac140 portable air con
Apr 01, 2009 | Heating & Cooling
Mistral mss20 split a/c only cooling somtimes 4 about 10 m then
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
Jan 24, 2009 | LG Art Cool LA1000PR Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
