Question about 1A Auto Parts 1998 Pontiac Grand Prix SE GM Style Black Lug Nut Cap Set of 5
Pistion replacement didnt mark pistons before tearing down engine block for 98 gm 3.8 v6
Will it matter what cylinder they go back into
  • 1A Auto Parts Master
  • 10,263 Answers
Nope...as long as you put them back on the rods the right way
Posted on Jan 17, 2014
Rebuilding oil pump for a v6 Buick & how to put the piston back in
Talking about the Buick 231/3.8L - YouTube
? 7:28
https://www.youtube.com/watch?v=PBx2MgVy1V0
Dec 24, 2012 - Uploaded by WhoSaidTyler
I have been told they have a kit for that oil pump which consists of a spacer ring and larger oil pump .... Will ...
GM 3100 V6 rebuild (3.1 litre) - YouTube
? 1:49
https://www.youtube.com/watch?v=gsAMtuTbE5U
Mar 6, 2012 - Uploaded by MET-TECH LLC
New main bearings, rod bearings, camshaft bearings, piston rings, head gaskets, ... oil pan gasket, oil pump ...
GM 3.8L V6 Engine Piston Slap audio with Video - YouTube
? 3:22
https://www.youtube.com/watch?v=SGCg1KHi2NU
Oct 12, 2012 - Uploaded by seriousNoodle
It turned out to be a loose piston and unbalanced torque converter. ... Stats on Engine: 3.8L V6, GM VIN Code ...
Dec 12, 2015 | Buick Regal Cars & Trucks
How to unlock a chevy 4 .3 motor
GM ( Chevrolet or GMC ) 4.3 L V6 Engine Tear Down ...
? 3:39
https://www.youtube.com/watch?v=-gkxF7wKIdk
Feb 1, 2013 - Uploaded by AutoEclinic
This video goes through the teardown process of a GM 4.3L V6. It has been removed from the vehicle and we ...
4.3L Vortec V6 Throttle Body Blade Mod - YouTube
? 13:54
https://www.youtube.com/watch?v=okEDVwlEHvM
Mar 21, 2012 - Uploaded by EricTehRedneck
4.3L/5.7L Vortec V6/V8 ' Throttle Body Blade Mod ' 262/350ci ... bottom of the blade to increase airflow into the ...
How To Clean Your Vortec 4.3L V6 Throttle Body - YouTube
? 11:21
https://www.youtube.com/watch?v=q8I67-GwXhM
Dec 09, 2015 | Cars & Trucks
Diagram spark plug wiring
my guess, is you removed them and didnt mark them?
the firing order?
what engine, there are 5.
to do this , one need to know 5 things.
2.5L, 2.8L, 4.0L and 5.2/5.9L engine displacements.
the distributor rotation direction CCW, or CW
and last the firing order, sometimes marked clearly on the intake manifold.
you must now where #1 cylinder is (always most front)
1989-98 2.5L Engine firing order: 1-3-4-2 Distributor rotation: Clockwise
2.8L Engine firing order: 1-2-3-4-5-6 Distributor rotation: Clockwise
4.0L Engine firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
5.2L and 5.9L Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
on a v6/v8 one cylinder is more forward. this is #1, look carefully.
Nov 26, 2013 | 1997 Jeep Grand Cherokee
How do i start to rebuild my 1996 dodge engine 5.2 liter
First thing is to tear it down and make sure you mark what pistons went in what cylinders. Then you will need to take precise measurments of the cylinders, looking for "out of round' and taper. This involves the use of micrometers. If the cylinders are within wear limits then you can just install new rings and hone the cylinder walls. If they are not then the block and all the pistons need to go to the machine shop for "boring out" the cylinders and pressing on new pistons. The crankshaft will also need to be measured at the bearing surfaces. If they are within wear limits then the crank can be polished and reused, if not then it has to be replaced. All cylinder head work needs to be done by a machine shop.
After all the measurments have been taken, the right size rings, and bearings can be ordered. Rebuilding an engine is not a task that should be done by a novice.
Jan 08, 2011 | 1994 Dodge Ram 2500
How to align camshaft to crankshaft when replacing timing chain on 4.3l gmc v6
Make sure you are on the compresstion stroke on # 1 cylinder its on the left side of the engine when the pistion is at the top of its stroke bolth valves on # 1 will be closed and won't open when the pistion is moveing up. Then look for the marks on the timing gears the cam faces down and the crank faces up they have to meat right on the money perfectly alinged and you should have now problems with timing issues
Dec 29, 2010 | GMC Sonoma Cars & Trucks
Were do i find my engine code ford mondeo 2005
Ford Mondeo Zetec 3 Digit code maybe found on the cylinder block adjacent to oil pan rail (oil sump flange) on the exhaust side, or on rear flange of cylinder block adjacent to crankshaft position sensor.
Ford Mondeo V6 Duratec 3 Digit engine code maybe found on lug at rear of cylinder block adjacent to oil filter and front cover of engine.
Sep 13, 2010 | Piston Keychain
What order do the wires go on the distributor cap
You didn't post your engine size so please use the appropriate diagram:
GM (Cadillac) 250 (4.1L) V8 .GM (Cadillac) 273 (4.5L) V8 .GM (Oldsmobile) 307 (5.0L) V8 .GM (Oldsmobile) 350 (5.7L) V8 w/EFI.Engine firing order: 1-8-4-3-6-5-7-2 .Distributor rotation: counterclockwise
GM (Buick) 252 (4.1L) V6 .Engine firing order: 1-6-5-4-3-2.Distributor rotation: clockwise
GM (Cadillac) 368, 425, 472, 500 V8.Engine firing order: 1-5-6-3-4-2-7-8.Distributor rotation: clockwise
GM (Cadillac) 429 V8.Engine firing order: 1-8-7-2-6-5-4-3.Distributor rotation: clockwise
May 12, 2010 | 1976 Cadillac Deville
I have a 1999 Dodge Dakota sport with a v6 magnum. Without warning it just blew a hole the size of a quarter in the oil pan. I am thinking piston but would like some input as to how to repair and if it is...
Think you are on spot with internal engine failure, most likely a connecting rod came through the oil pan, there should have been some knocking just prior to it happening, though stranger things have happened. You are at a minimum going to need a rod and piston for that cylinder, although I would bet you will need more than one. Machining or replacing the crankshaft will be necessary, and these are just the effects of whatever caused the problem in the first place. . So in essance you will end up with a rebuild because you will not want to tear the engine all the way down and not rebuild it. My suggestion is to locate a good used engine and just replace it. That is what I would do if it were mine. But if you have the funds your best bet will be to at least put in a short block. No matter what you are in for in depth, major engine repair or replacement.
Oct 17, 2009 | 1999 Dodge Dakota
Im replacing my piston and rings and i took the cylinder and cylinder head out and i dont know how to time the engine , the sproket has a mrk on it and i dont know if i shuldput the piston all the way down...
Below is a generic diagram. If only one mark is present it points upward and in line with the crankshaft center line. If two marks are present they line up with the gasket surface of the cylinder head. The piston should be on TDC and the cam lobes should be pointing downward. Be sure the chain is on the crank sprocket, not wedged between the sprocket and the balance weights. Also be sure that the chain is taught on the front side of the engine. Any slack should be at the back side of the cylinder so the chain tensioner can work properly.
Can I get a “very helpful” rating on this answer?
Aug 23, 2009 | 2005 kawasaki KDX 220 R
What are the timing gear specifications for 1992 Honda Accord 2.2L. am replacing the timing belt and gear & need to align timing marks. thanks
manualy turn the engine over to the first cylinder. (place screwdriver in cylinder through spark plug hole) when the pistion is all the way up that is top of cylinder #1 . at this point ther should be marks on the gears and on the block that align. if not than mark them your self with a paint marker. now loosen the tensioner to remove belt, and install new belt. be careful that all marks are still aligned that is a zero clerance engine. meaning that being one tooth off will colaps a valve.
Aug 15, 2009 | 1991 Honda Accord
1A Auto Parts 1998 Pontiac Grand Prix SE GM Style Black Lug Nut Cap Set of 5 Logo
57 people viewed this question
Top 1A Auto Parts Tools & Hardware - Others Experts
Pete Bruk
Lawrence Oravetz
William Alequin
Are you a 1A Auto Parts Tool and Hardware - Other Expert? Answer questions, earn points and help others
