Question about Garden
MY 7524 WILL NOT START-CHANGED THE PLUG--HAVE TO USE PULL CORD TO START---ELECTRIC START BROKE--PLEASE GIVE ME ADVISE TO START.USED A TOTAL OF 12 TIMES.
IT HAS NOT STARTED IN OVER 18 MONTHS
  • Garden Master
  • 2,478 Answers
Pour a little gas in carb.
Posted on Nov 28, 2012
  • 211 Answers
SOURCE: My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
panilling9
  • 284 Answers
SOURCE: Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
Posted on May 25, 2009
  • 580 Answers
SOURCE: I got a Craftsman Eager 1 6.75 Electric start
There is a charger plug that needs to be plugged in to to an A/C charge adapter that plugs into a wall outlet looks like a wide plastic gator clip they break easily. Make sure your friend gave you this adapter.
Make sure the rechargeable battery you jus bought is fully charged the usually need to be plugged in for 48 hours for full charge to occur. If all this is good change the spark plug. If this does not o it call a local mower repair place like Tony's Not SEARS but first look on your mower there will be model numbers. You will 1 on the engine 6-10 digits and at least 1 if not 2 on the frame this will tell the repair shop all they need to know. To replace your pull recoiler Good Luck To You!!
Posted on Jul 08, 2009
SOURCE: new lawn boy mower pull cord will not pull. Worked first 2x
Actually we ended up taking it back to the store we bought it at and since it had been less than 30-days they did not even look at it or attempt to fix it, just gave us a new one.
Posted on Aug 15, 2009
mowerman1857
  • 389 Answers
SOURCE: trouble shooting electric start toro 20074
Check battery connections, make sure they are clean and TIGHT!
Check the harness where it plugs into the starter switch
Check the harness where it plugs into the battery wire harness
Check the cable at the starter, make sure it is clean and TIGHT
If you need it, you can go to toro.com and enter your model number and download both the Owner's manual and a parts manual if that helps you any
Posted on Oct 04, 2009
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
The pull cord on my Cub Cadet OHV 173cc self propelled mower broke.. I'm somewhat handy and should be able to fix it myself, however I've never done this before. I have the engine housing...
Yeah I got the same problem. My pull cord broke in the first season. On my own once the plastic cover is removed, 4 phillips screws, the cord housing is secured by 3 10mm nuts. Remove them and lift out the housing. On my own unit the spring had also slipped out of the mount on the shaft securing the assembly (another 10mm socket nut will loosen that). I used a Briggs and Stratton cord from another (truly dead) mower and have had no problems since then. I am not sure why folks are giving you spark plug settings when you are asking about the cord. :)
Aug 14, 2011 | Mtd 19 In. 173 CC OHV 3-In-1
Compresor will not start under pressure
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However it's not adviseable to run without the thermal reset for an extended time. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background, that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit with no extention cord. But, when using an extention cord, I have a 10 guage cord that will carry the load needed to run the EC12. I also have changed to 100% synthetic oil.
Jul 23, 2011 | Hitachi EC12 Portable Electric 2hp Air...
Pull line broke.
Remove the starter housing from the engine, then unwind the rest of the cord from the reel. With both parts of the cord, measure the total length of cord plus some extra for knots. Take one of the remnants with you to a saw service shop for replacement cord purchase. You might even take the entire starter mechanism and have them rewind the cord for you if you don't feel comfortable about installing the new cord. When done, just reinstall the starter on the saw and attempt a start. Good luck!
May 17, 2010 | Garden
Grill problems
I would advise not to use the grill or the plug it plugs into before determining what the problem is. It could be the grill cord, or the wall plug.
If you have been in the habit of pulling the cord plug out of the wall by tugging on the cord, then chances are the problem is broken conductors inside of the wire insulation. One way to test this is to attempt plugging the unit into a totally different wall outlet. If the cord and outlet heat up again, chances are the cord needs to be replaced (if possible). If the both do not heat up, then the outlet wiring connections inside of the wall need to be checked.
Bad wiring connections either in the wall, or in the cord, will generate heat, when will then conduct to the other connector. So it is difficult to use heat as the indicator of which connector is bad.
Dec 10, 2009 | George Foreman GR36P
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
I got a Craftsman Eager 1 6.75 Electric start mower from a friend but it will not start, the electric start does not work (is there a fuse?) for that, I tried a new 12 volt battery NOTHING! Then when I...
Jul 08, 2009 | Craftsman Garden
The pull cord on my toro powerlite snowblower wont retract
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Jan 01, 2009 | Toro Blowers Rake and Vac - Electric...
Gas powered ryobi trimmer will not start
Hi
I found that the plug that came with my unit had an intermittent fault (sparked sometimes, then not all) definately the plug in my case. And yet at first, seemed to start OK, progressively got worse.
OK so youve changed the plug! Now check for spark....Can you see the spark if you pull the cord a few times
(you have to unscrew the plug from the head but leave it connected to lead & rest the plug against the metal cylinder surface using a pair of pliers to steady it and so you dont get a small shock)
If youre getting visable spark when you pull the cord, suspect fuel feed blockage from carb, Test by: Prime the bulb & turn to full choke, pul the start cord, Is there petrol vapour/odour present within the cylinder with the spark plug removed.
Check also gauze air filter behind the roto choke knob is clear, on/off switch (could be damp wd40) Test compression put your finger over the open plug port, plug starter cord, should be a little pressure build up
Hope this helps
please rate my comments - thanks
Aky1967
Jan 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
