Samsung LN52A630 power LED keeps blinking, won't turn on
  • 257 Answers
SOURCE: can not power it on, the power LED keeps blinking.
Most likely, the power board was defective. You need to replace it.
Posted on Aug 18, 2009
  • 11800 Answers
SOURCE: power & OPC lights keep
That signal the fact that the power source is in protected mode - a component has failed in the tv and now acts as a short. When the power source tries to start the failed component starts to draw so much power that the voltage drops; this trigger the protection system of the source that shuts it down to save it from frying.
To fix the tv you will need to open the tv and test the voltages on the output rails of the power source to find out which one is triggering the shut down. Then just follow it to the failed part. This requires a good electronics experience.
In your tv the most usual part to fail is the sound board: the radiator on the audio amplifier is undersized so the amplifier overheats and fries. The sound board will have to be replaced - a $250 job at a repair shop.
Posted on Jul 14, 2011
ekcnoel
  • 998 Answers
SOURCE: Hi. I have a samsung
Sir it indicate that there is a shorted part, common parts are the regulator and the bridge type rectifier try to check this part or replace them or you can contact a service technician to do it for you and save you from stress good day and best regards.
Posted on Sep 11, 2011
  • 302 Answers
SOURCE: My Samsung LN40A650A tv won't
if you have no lights at all i would check the power supply.
You can get get parts for this tv at www.interliquidparts.com
Posted on Nov 26, 2011
  • 11 Answers
SOURCE: westinghouse 40 led tv... Power won't stay on...help!?!?!
sounds like a bad prejector bulb
Posted on Apr 13, 2012
I have a Samsung LN52A550P3FXZA. The TV does not come on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 26, 2016 | Samsung Televison & Video
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
Feb 05, 2012 | Samsung Computers & Internet
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
When the tv is turned on I hear a loud grinding like noise
May I know if the unit won't power up, has a three blinking led light at the front panel? Also, please check if the grinding noise is near the lamp assembly.
Mjsazon
Dec 01, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung 56" Model HL56A650C1FXZA will
Mine is doing the same... anyone find a solution?
Jul 05, 2011 | Samsung HL56A650 56 in. TV
I have Samsung HL-S5087W for about 5 years and it is turning off by itself-any suggestions?
i hope your TV is getting ''off '' by itself when you are trying to turn ''on'' - not when you are watching TV...........then following is the situation ..........IF LED IS BLINKING then---- usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore.....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact samsung service centre.........
Apr 22, 2011 | Proton MM2701VT 27" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
