Question about Dell Axim X50v Pocket PC
Won't go to the main screen
It will show the dell's logo but won't go to the main screen no matter i tried soft and hard reset.
please give me your advise.
  • roland_3rs Jan 14, 2009
    How can i reload the rom/firmware/software to my PDA? I don't have the software and my PDA is not working.
    my active sync can't detect my PDa, so I can't update it.
  • 827 Answers
A hard reset basically wipes all information stored on the drive.
Download the software to flash it from here.
You push the wireless, power and reset buttons to get to the flashing menu.
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
  • Dell Master
  • 19,396 Answers
You need to reflash the Dell Axim with the proper image.
Here is Dell download page.
How to Flash Dell Axim x51v and install WM 6.1 - xda-developers
Hold down the wifi button and the power button at teh same time, then press reset button. Release wifi and power button to get in teh SDboot menu.
  • Dell Master
  • 13,433 Answers
The Dell is unable to complete the startup, you may have a software issue, or a hardware problem, this might be fixable by reloading the rom / firmware / software into the pocket pc. If that doesn't solve the problem the last option is to send the device to dell repair service, I will have a look around and let you know if there is a software update available and if there is I will post you the instructions soon.
  • 2 more comments
  • Ekse Jan 14, 2009
    what is the operating system currently installed on the PDA, 2003 se? Have you done any updates to the OS?
    This system update will reload the software
    http://support.dell.com/support/download...
    Download and run the exe file on your computer, it will extract the files.
    You will need to have Active sync 4.5 or newer installed.
    connect the device to the computer.
    go to the folder you extracted the files, and run the AximUpdate.exe
    If any problems come up, let me know.
  • Ekse Jan 14, 2009
    If you are unable to reload the software into the pda via usb, the update needs to be done on SD card, with the pda in bootloader mode.
    The rom is included in the exe file and is extracted into the folder you selected.
    what we need todo is to write the rom into a sdcard, we can't just copy it, it needs to be written into the sdcard with a special program. and then the pda needs to enter bootloader - program rom from sdcard.
    I will have to look into that again, as I don't own this model myself.
  • Ekse Jan 14, 2009
    what happens when you run the axim update? without the pda detected by active sync?
  • Ekse Jan 14, 2009
    Right now I need to know what version operating system was installed on the axim? 2003? 2003 se? wm5? wm6?
    Also note if we are unable to load a firmware into the device even on bootloader, then there is no other option but to send it to repair.
    Attempt to start in SD Bootloader mode by Pressing Wireless + Power + Reset.
    Does the Bootloader mode work? are you able to enter to it?
  • 55 Answers
Hold the wifi button together with the power button.. than push the reset butten. Release the wifi and powerbutton and you're in the SD boot menu (when using the record button in stead of the wifi you'll enter maintenance mode)
If that doesn't work you can always reflash it. If you need to do that let me know and I will get you a guide and walk you through it
  • Shawn McGuire
    Shawn McGuire Jan 14, 2009
    Note: Pushing the wifi button, power button, and reset button is how you are able to flash with a new ROM or Firmware.
  • Shawn McGuire
    Download
    1. Click Download Now, to download the file.
    2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
    3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
    4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
    Install
    1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
    2. The Self-Extracting window appears and prompts you to extract or unzip to C:\DELL\DRIVERS\R12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
    3. The Self-Extractor window appears.
    4. Click OK.
    5. After completing the file extraction, if the Self-Extractor window is still open, close it.
    6. Click the Start button and then click Run.
    7. Type C:\DELL\DRIVERS\R12345 in the Open textbox and then click OK.
    8. Follow the on-screen installation instructions.
    You can get the download from dell here: http://support.dell.com/support/download...
MY DELL DESKTOP WILL NOT REBOOT OR START
Try to replace the ROM. Also, try adding a new hard drive. See what happens.
Jan 24, 2014 | Dell Computers & Internet
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
At&t fusion won't turn all the way on
at&t fusion1 firstly it stuck on the at&t logo then i did the hard reset so it start showing pink screen or some time it showing blinking at&t logo.can u find me a solution
Apr 06, 2012 | AT&T Cell Phones
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear...
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Jan 14, 2009 | Dell Axim X50v Pocket PC
I have a Dell Axim x50v running with original ppc2003. Then I upgraded it to Windows mobile 2005, and used for couple of months then it crashed! Now the issue is both soft & hard reset stop loading at 80%,...
Same problem. Soft and hard reset can't even stard any advice screen. When the problem started, it was frozen at the dell round simbol, that i just could turn it off by removing battery. Now, its even worse, the screen is off, even after pressing the two and tree buttons at the same time, it doesn't hard reset. What else should i do?
Mar 28, 2008 | Dell Axim X50v Pocket PC
Dell Axim X5 with Pocket PC 2003 Locked up
With much regret I did a hard reset. It appeared that some how in my carrying case that hard reset got started and I could not get it out of the lock up with out taking it clear through. I hadn't backed up for a couple of month but didn't loose much data. Thanks for the follow up.
Mar 17, 2008 | Dell Axim X5 Pocket PC
Dell Axim X50v Pocket PC Logo
Alun Cox
