AsRock Motherboard won't boot. Need Advice.
My Asrock motherboard will not boot. I have A 2.4 processor and 1GB . The problem is nothing appears on the screen when I turn it on. I have checked the graphics card and concluded that is not the problem. It has to be the moterboard or CPU. When I turn the Computer on it gives power to everything,then stop cpu & smps .
check RAM SMPS HDD & DISPLAY CARD ok.
    Sergeant:
  • Computers & ... Expert
  • 276 Answers
First check the power supply or swap another.
connect only power 20 or 24 connect and test power on. no off? (no video because no power to cpu by 4 pin or 6 pin connector)
plug 4 pin connector and test power on. if on and off check cpu power section (mosfets) if burned one pls remove ... you can test short by touch the mosfet by finger (burning heat)
Posted on Oct 11, 2016
  • 158 Answers
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Posted on Jan 10, 2009
Hello, my system has Asrock P4I45GV Motherboard.
your possessor fan dos not properly work or fan casein do not properly instal or your power supply faulty.
Sep 04, 2013 | Asrock P4I45GV R5 Motherboard
Problem with upgrading ram on Asrock 775i65G Motherboard
Hello download the manual here:
http://www.asrock.com/mb/Intel/775i65G/?cat=Manual
It explains the problem.
You will need adobe reader, to read content.
Good luck
Feb 01, 2013 | Asrock 775i65G Motherboard
Have Comp. w/Asrock MOBO.It's been sitting
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
THIS MOTHERBOARD SUPPORT PROCESSORS WITH 2 CORS ?
http://www.asrock.com/mb/cpu.asp?Model=K8NF4G-SATA2
looks llike you can put an amd Sempron-64bit cpu in.
Oct 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
How can i install my asrock 845 celeron processor sound and video controller driver ?
Download drivers for ASRock 845GV-M from;
http://www.asrock.com/support/download.asp?Keyword=&Socket=478&Model=845GV-M&OS=XP
Regards;
Hassan
Jul 30, 2009 | Asrock 845GV (P4I45GV) Motherboard
Asrock K7VM2 m/b reading RAM
Its hard to say try just using one stick and booting up if it reads all that then its a ram if it doesnt then it seems like it could be a bios or m/b issue
Feb 11, 2009 | Asrock K7VM2 Motherboard
My computer is not working
have u tried to boot into bios switch it over to optimal settrings or default settings and save and try to reboot
Aug 17, 2008 | Asrock 775i65GV Motherboard
MoBo turns off after booting
hey, this victor from kenya. Have you confirmed that the heatsink n coler fan is firmly attached to the motherboard? suc error is usually as aresult of non efficient cooing systems.
Also reapply the cooling compound. Use methylated spirit to clear tha old application on the surface of your processor.
If this 2 fail,confirm that you are using a compartible processor to the asrock motherboard.
Jun 27, 2008 | Asrock 845GV (P4I45GV) Motherboard
No power
check your processor it might be incompatible with your new motherboard.
  • Check out you motherboard manual for supporting processor list, or view on your motherboard manufacturer's site.
Thanks
Iqbal
May 17, 2008 | Asrock P4i65GV Motherboard
Computers & Internet Logo
582 people viewed this question
David Payne
David Payne
