Have a sylvania srt 2027 27 inch tv horizontal line no picture but have sound
Has horizontal line no picture but has sound
    Top Expert:
  • Televison & ... Master
  • 73,619 Answers
The vertical scan output section circuit is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 28, 2012
nfandres
  • 168 Answers
SOURCE: Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Posted on Mar 10, 2007
premtech
  • 934 Answers
SOURCE: JVC AV 35750 single horizontal line
Jeremey,
It's ring cracks on the solder joints of the vertical IC... IC421 i mounted to a small heat sink on the board. With the unit off and unplugged remove the board and locate IC421 (LA7832) and closely examine the pins connecting this component to the foil side of the board. You'll notice small rings around the footings that are actually open cracks in the solder, caused by heating and cooling over a period of years. Simply and carefully reflow some solder over these cracked joints, careful not to get the ic too hot in the process, and put it back together.. That should sole the problem...
Another problem we encounter a lot in the vertical deflection circuit of this unit are the two feeder caps C424 (100UF/35V) and C425 (470uf/35v).. If you're already there you might want to go ahead and replace these as well - save taking the back off again if they go bad..
Bill
Posted on Nov 13, 2007
  • 45 Answers
SOURCE: Nopicture
No vertical deflection. Vertical output IC, caps.
Posted on Nov 25, 2007
  • 2315 Answers
SOURCE: 33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Posted on Jan 16, 2008
  • 579 Answers
SOURCE: 32 inch jvc av-32d302
Those are called retrace lines. The electron beam has to go back to the beginning of the screen as part of its raster scan. Normally it is turned down so that it can't be seen. There is a little adjustment knob on the high-voltage flyback transformer called "screen" that will hopefully adjust this for you. If that doesn't work it is an indication that the high voltage circuit is dying.
Hop Ya Fix It.
Posted on Feb 01, 2008
Sylvania 21" no picture, but one horizontal line in center
Vertical scan output section circuit fault. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Dec 18, 2015 | Sylvania Televison & Video
Sylvania lc320ss8 horizontal bar discoloration
Do you have tv repair exp. If not then take it to a shop.If you do then reseat the plugs on the T Con board ( Timing Control). If that don't fix it then go on E-Bay and get a price on a used T-Con board and try that. Those boards have a high rate on going bad.
Jan 13, 2014 | Sylvania LC320SS8 32 in. LCD Television
My 27" ( aprx 6 yrs old)Tv first had only a horizontal line across the screen about 1/2" wide, good sound but no picture, now it only clicks like its turning on and off when you plug the tv in, no pictue...
It has gone into a self protect mode where it will shut down because you have a fault in the frame stage of the TV (horizontal line). This will most likely be a failure of the frame output IC. Replace this & you should restore the normal picture.
Oct 11, 2009 | Sylvania Televison & Video
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Sylvania 6842PE 42 inch Plasma Fuzzy picture and horizontal Lines
USUALLY THIS PROBLEM IS CAUSED BY A DEFECTIVE X OR Y SUSTAIN BOARD. ESTIMATE BETWEEN $300- $700
Apr 03, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
TV picture won't open.
The vertical sync circuit has gone bad...you'll have to have it repaired if you want to keep it
Jan 03, 2009 | Televison & Video
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
