Question about Simplicity Sewing Machines
Simplicity SL 700 serger will not chain stitch
SOURCE: HELP!
Hi, I have a Simplicity easy lock 804D serger and I have the owner's manual, and I'm able to give you a copy if you don't have one, I need the foot control, and I don't know how to take one.
my e-mail is ana_agui@hotmail.com, I leave in Florida, in fort myers.
God Bless you.
Posted on Sep 17, 2008
Zenqi
  • 208 Answers
SOURCE: My brand new Kenmore serger
The loopers must be threaded before the needles.
Make sure that the needles are not threaded. Thread the loopers and have the loose ends behind the presser foot. Then re-thread the needles and place a scrap of fabric under the foot and sew. Make sure that the edge of the fabric is not to the right of the plate, but where it would be if the knife had cut it.
Posted on Jun 17, 2009
  • 136 Answers
SOURCE: wont stitch
If threaded correctly and it will not serge, you have probably just found out why it was in the garage sale. Take it to a qualified repair shop, mmost give free estimates, probably much more than you paid for it.
Posted on Jul 04, 2009
  • 152 Answers
SOURCE: Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Posted on Oct 15, 2009
  • 46 Answers
SOURCE: My Evolve serger is skipping stitches while using
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Posted on Nov 27, 2009
Testimonial: "Thanks I am going to try this as soon as I can, but right now occupied with a job with my industrial machine. My only issue may be with the needle."
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
How do you lengthen stitch. The stitches are so close together it looks like a satin stitch. I have no manual for it. thanks!
your machine should have a stitch length dial on the right hand side above the flywheel, it might have numbers from 0.5 to 3 or 4, higher number for longer stitch (effectively this moves the foot and feed dogs faster in relation to the needles to make the stitch longer).
If you have the Serge Pro SW432 that your enquiry is linked to and you have not used a serger before, then definitely get hold of the manual, you will need it. Sergers are very different to sewing machines - once you've mastered one, its easy, but there is a learning curve.
Firstly, ALWAYS extend the thread aerial up, you'll see loads of images of sergers sitting nicely with the aerial in the lowered position, great for moving them to avoid damage. But they won't work well, a serger seams at 1500 stitches per minute and the thread streams off the cones so you need to ensure there is a good clear feed via the aerial to the tension dials.
Buy good quality thread cones and keep it out of the sun and dust. Cover your machine when not in use (lower the aerial first). You could start with white, grey and black thread as this will cover a lot of fabric prints/colours etc. To change thread colour, you will need to cut and knot on the new thread for the two loopers (right hand side cones) - do this about 6 inches above the first thread guide, and then chain off to feed these through down to the needle plate, when you see the new colour come through okay, stop. Repeat the process for the needle thread or threads (3 or 4 thead depending on what stitch you are sewing) but stop chaining when the thread knot is above the needles. Stop, loosen these tension dials and pull the thread down, cut out the knot with scissors and thread the new colour through the two needles. Use threading wires if you have them, or tweezers. Pull both these and the two looper threads together under the pressure foot, lower the foot, turn your tension dials back to 5 and chain off. The thread sequence is important, mostly top looper, bottom looper, then needles, this is so much easier demonstrated than explained.
If you can find a classroom/shop offering overlocking user lessons, go take a couple, its well worth the money. Otherwise go to you-tube and watch all the videos you can search on sergers, threading, etc.
Good luck with your serger, please respond with 4 thumbs if this has been helpful to you. :-)
May 19, 2011 | Simplicity Serge Pro SW432 Mechanical...
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
Sep 12, 2009 | Husqvarna Sewing Machines
HELP!
God Bless you.
Jan 04, 2008 | Brother 925D Serger
Sewing Machines Logo
124 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
