Acer M3970 Can't Start
This Computer Cant start, fan processor working, but can see any reaction on monitor, just blank and goes to monitor standby with processor fan working on max power, has been try to replace RAM and Processor with no result, no beep sound while i try to remove the RAM Trying to detach bios battery for more than 30 minutes and reset it with jumper, also with no result, any advice for this case ?
  • 32,281 Answers
B> Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 27, 2012
Testimonial: "Thanks for your respons, but i've try your instructions before i post here, there is 4 slots of ddr3 on that MB, and i try it all with no result, also with new RAM. When i remove that RAM, there is no beep sound message that indicate the RAM is not attached in that slot like the normal computer. The Processor seems not working, the temperature was not raise to warm or hot, just cold like before power up the computer, not like a normal computer even that computer only working for a few second, the proc will be warm."
  • 3 more comments
  • De Premor Nov 27, 2012
  • Chris Hingee
    Chris Hingee Nov 27, 2012
    It looks like a motherboard fault or a CPU fault.. Depending upon the age of the computer, it maybe better to get a new computer or motherboard. If you decide to get a new motherboard and CPU check the switch mode power supply and the existing components will connect to the new motherboard.
  • Chris Hingee
    Sorry about my last post, please ignore the comment about the power supply etc. it does not apply to laptops. A laptop motherboard replacement may not be the cost effective solution depending on the age of the laptop.
  • De Premor Nov 28, 2012
    Thanks Chris, this is a new desktop computer, we just used for 2 month, and now come with this problem, i think soo, that is the motherboard fault, has been try to raplace almost the the other part except that motherboard with no result, will try to replace that part
  • Chris Hingee
    Chris Hingee Nov 28, 2012
    If the computer is only 2 months old then it will still covered by a warranty. I suggest you return it to the supplier for a repair or replacement.
  • 128 Answers
SOURCE: ACER blank screen
your lcd screen maybe damage due to impact i suggest you bring it to the computer shop for repair. most common damage are the screen and harddrive due to strong impact.
Posted on Oct 16, 2008
SOURCE: wont start or boot up
I had the same problem and found that disconnecting the power lead and repositioning the ribbon cable from the on switch did the job after about 5 attempts
Posted on Mar 06, 2009
darkdragons
  • 835 Answers
SOURCE: ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
Posted on May 23, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Have an acer 5510z notebook Model BL50. I want to
I do not believe the Acers have reset buttons or switches. I have reset the Cmos by removing the cmos battery, shorting the two pins with another cmos plug with the wires connected together. I then powered the motherboard up until the BIOS loaded, but you don't have to, to reset it. I then powered down and removed the shorting plug. I put the motherboard back in the case and rebuilt the laptop. The system booted right up with no password, got into the BIOS and reset the information.
Posted on Sep 15, 2009
Testimonial: "Thanks parrothead. Will give that a try."
  • 159 Answers
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Posted on Oct 29, 2009
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
When i switch on the monitor the on/off button blinks and i don't get a picture. johanalvemalm@people.net.au
Most monitors will behave that way if they don't get a signal from the computer so there's nothing to display. A quick check of the monitor itself is to disconnect the signal cable from the computer and then turn the monitor on. Most monitors will display some kind of a message that there's no input and to check your cable connection. Then the power indicator changes color as the monitor blanks out.
You will probably find that your computer isn't starting up when you turn on the power. A common computer problem is that it will turn on when you press the power button, showing a power light and you'll hear the fans inside start running, but it never actually starts running. Then there's no video to the monitor and you see the trouble you described.
The monitor may still be bad. If everything seems to be starting normally and you hear the Windows startup sound through your speakers, but the display stays blank, try another monitor. If that one works, you'll need to have the bad one serviced or replace it. If the test monitor is also blank, the video circuitry in your computer has failed. If the video is built into the motherboard, you can install a plug-in video card as a replacement.
If the computer is turning on but never starts running, that can be a pain to figure out because several things can cause the trouble. The most frequent causes are a bad power supply or motherboard. Bad RAM or a defective drive or other device connected to the motherboard can also keep the board from starting up. The processor itself can fail, but that's not common. I start by removing everything except for the power supply, processor and fan to see if the motherboard is starting. If the motherboard doesn't give a "no memory" error (usually a long beep), you need a power supply or motherboard. Otherwise, the basic hardware is fine, and you can start replacing parts until the trouble comes back, and then you'll know what caused it.
Good luck, and thanks for using Fixya!
Dec 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
I have a latitude D600 notebook, and connected 1905fp lcd monitor it has been working for few years without problems. Now lcd displays information for 2 seconds and the screen goes blank. I know the LCD is...
please try it without the lcd i mean use your note book without the external lcd, am sure your system has a processor and or processor fan problems try lose the computer and blow it, i mean the cooling fan of the processor, if no avail, then you will need a new motherboard for your system, but am pretty sure its the processor that is fulty, thanlks
Jul 17, 2009 | Dell UltraSharp 1905FP LCD Monitor
Monitor just went blank, no power light.
Was the PC running, and then shut down? Or, did it never start in the first place?
It sounds like it could be one of many things. Sometimes if the processor fan has failed, the computer will start up, and then shut down. Also, bad memory can cause the PC to shut down.
Jul 05, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Computer fails to start
First,Check the monitor on another computer,If it works we can go from there.
May 13, 2009 | Acer Computers & Internet
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Dec 08, 2008 | Acer Ferrari 4000 Notebook
Acer Screen goes blank when fan comes on...Help!!!
Hi...there,
It's seems your backlight inverter are busted. Need to replaced a new one...
Nov 27, 2008 | Acer AL1511 15" LCD Monitor
Monitor N taskbar
You might try to blow out the heat sink/fan for the processor with some canned air. It's possible that the lcd is having issues (backlight/inverter. How long does the lcd work normally before it goes bad? thanks
Sep 23, 2007 | Compaq Presario 2100U Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
