Question about Brother IntelliFAX 2800 Laser Fax
Our fax doesnt want to recieve it sais sleep mode
The fax sais sleep it is a 8360p model
    Champion:
  • 320 Answers
Have you tried to turn it of then on to reboot the fax machine! if that will not work you may have a bad main board
Posted on Jan 16, 2009
There is nowhere I can find whether I should switch on the Machine 24hr a day x 7 days a week. Or shall I swtich it off after-office-hours? Any effect on the life-span of the machine?
In a business environment most fax machines are left on 24/7......who wants to miss an order coming in because your fax was OFF. However, many fax machines can be programmed to go into a "sleep mode"...this would be in the evening when the office is closed...you still want to be able to recieve fax's if any come in..but you don't need the machine ON "fully" ready to print. Another-words, the machine is in a sleep/half power mode( because no-one is in the office to use it )..BUT if a fax comes in then the machine can still recieve it, then it "wakes-up" fully..prints out the recieved pages, and then goes back to sleep again. The details on how to program this function will be in your operators manual IF the feature is available on your model.
The benifits of programming a machine this way are pretty obvious...savings on Hydro, extended machine life ( due to machine going to sleep.) and yet you still dont miss any calls.
Pretty good hey.!!
Nov 07, 2010 | Brother IntelliFax-2820 Laser Fax
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
Our fax is on sleep mode...how do we get it off that mode and able to recieve faxes?
you can tun it off by using the settings setup . it should send and receive even in sleep mode
Jan 08, 2010 | Brother IntelliFAX 5750e Laser Fax
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Our Brother Fax Machine 2820 stays in sleep mode. How do we get it out of sleep mode?
Machine goes into sleep mode when not being used When it recieves or you copy something it will come out of sleep mode If its not recieving then you need to check your recieving settings
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Can not recieve Faxes
These machines goe into sleep mode automaticly and should exit when they detect a ring.
You MAY have a problem with your main board.
First make sure your phone cord is plugged into the correct port. There are two, line and ext. It must be plugged into line.
You can try a factory reset if that doesn't work. Unplug unit, hold menu button, plug back in and wait for lights to blink and display to read Maintenance.
Press 0 and 1
Now press 99
Now try sending to the machine again.
If this doesn't work, you likely need the unit serviced.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Sleep
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
May 15, 2007 | Brother IntelliFAX 5750e Laser Fax
Sleep mode
Press Menu/Set, 1, 6, 2 (2. Sleep Time should be displayed) Simultaneously press Start and Options at the same time Press Menu/Set Press Stop Exit This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Sep 13, 2006 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
152 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
