Question about Pride Travel Pro 3-Wheel Mobility Scooter
Will not move
The battery is full--the lights are on but will not go forwards or reverse
Wahooa is Florida's leader in Watersports and Excursions
We are the local experts for Jet Ski Rentals, Parasailing, Boat & Yacht Rentals, Snorkeling and awesome excursions.
We operate in the most popular tourist destinations in Florida including Miami and Miami Beach, Ft Lauderdale, Florida Keys.
Wahooa Travel Adventure Around the Corner
Posted on Aug 13, 2016
2 Suggested Answers
  • 29 Answers
SOURCE: Legend SC3000 has a full charge but will not move
lets look at that model number and seriel number. I can look up it's history. Take the batteries to Advance or Auto zoon, Get them "Load Tested" it's free. Are there any flash codes or beep codes. the light on the console will flass or a beeping noise after you turn it on ? these are codes which we can tell what can be a problem. mike
Posted on Sep 09, 2009
Club Car cart will not move forward---works fine in reverse
check the forward/reverse switch. Possibly a loose wire. Unhook the battery and go to each wire and verify it is connected properly. Then reconnect the battery.
Aug 15, 2015 | Golf
Despite wiring speakers correctly they remain out of phase. I know that reversing the connections resolves this problem but it has caused problems when playing 4 speakers simultaneously i.e., I need to...
I have no idea how you determined they are out of phase. Normally if you change all of them the result is the same. Just change the one (swap the speaker leads) that is out of phase.
First assume they marked on the amplifier typically red and black connections. Then check the speakers to see if they are also marked the same way, if so match the colors.
If they are not marked you need to be able to see the cone, that use to be easy. Use a battery and connect it across the speaker leads, I use a flash light 1.5 volt battery. You may have to go to a 9v but try the 1.5 first. When you connect the battery the speaker cone will either move forward or reverse. If the cone moves in reverse when connected swap wires. When the cone moves forward just mark with the plus (red) coinciding with the battery.
Nov 28, 2014 | Audio Players & Recorders
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
Legend SC3000 has a full charge but will not move forward. It moves in reverse just fine. It will move forward every once in a while, but the distance it goes varies. Sometimes 5 ft other times up to 200...
Sep 03, 2009 | Pride Health & Beauty
Gas gauge moves from full to empty to half, while idiol.
Traction Light has a traction system sensor going bad.
Blinker rapid flash- brakes applied, Need to replace dual function tail lamp bulb(brake turn
bulb)
Reverse light need shifter adjustment.
Gas gauge The sending unit in your tank is going bad replace it.
Mar 19, 2009 | 2001 Oldsmobile Silhouette
When i put my car in reverse it won't move but will drive forward perfect and is full of transmission fluid
Assuming this is an automatic transmission, odds are you have lost a band in your transmission, this will require a rebuild,  you may also notice it will fail to shift into high gear as well?
Oct 29, 2008 | 1984 Oldsmobile Delta 88
Pride Travel Pro 3-Wheel Mobility Scooter Logo
98 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
