Question about Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate Free Agent (I: ). When I go to explore I get a message telling me to insert a disk. Usually when the device is connected, Windows XP brings up the message box asking what to open the disk with. It no longer does that. The disk shows up in Device Manager and says it is working fine. When go to Manage from My Computer and select Disk Management., Seagate shows up but without it?s letter. When you right click on the device to change the path, it only says Help instead options. Also, in Disk Management, it designates disk 2 as removable disk II) and disk 3 is Seagate Free Agent with no letter designation. I have all of my backup software, programs, mail backup, artwork and data on this drive and sadly did not back it up. I need to access this drive. Please, can you help my to get windows XP to connect to the device? I have tried a gazillion suggestions and nothing has worked.
  • JesMe Jan 10, 2009
    Thanks so much. I have tried it on another computer with the same nasty results. I can access the data through a recovery program called GetitBack. i am trying to find something a little bit cheaper. I am just glad that the data is still in tact. Once I get the data, I will try your suggestion.... Thanx :)
  • Seagate Master
  • 32,281 Answers
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Posted on Jan 10, 2009
Recovered my pc,lost seagate manager somehow
Go to http://www.seagate.com/www/en-us/support/downloads/ and select your product then you can download any documentation and drivers that you need.
Mar 01, 2010 | Seagate FreeAgent Pro 1TB External USB...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Dec 24, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
264 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steve
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
