Question about Garden
Oil / petrol ratio for Parkland whipper snipper
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Posted on Sep 15, 2009
Testimonial: "Thanks, will try it!!!"
  • 203 Answers
SOURCE: My whipper snipper is petrol 2 stroke and does not
May have a screen in the exhaust that has plugged up with carbon. You can take the screen out and it will run properly if that is the problem. Otherwise, it could need a carburetor cleaning. If you are going to rebuild the carburetor, you probably should get a carburetor rebuild kit from a small engine repair center for your particular model.
Posted on Dec 29, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
  • 122 Answers
SOURCE: what is the correct fuel
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Posted on Feb 08, 2011
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
What is the ratio for oil to petrol for mculloch whipper snippers
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Jan 24, 2012 | Garden
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Oil water ratio tanaka TBC-2251 whipper snipper
You must mean oil to gas ratio. I suggest following the instructions on the container. That is what I usually do. Best regards.
Jan 02, 2011 | Tanaka Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
