Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
I have dead spots on a gtco roll up II digitizer.
SOURCE: Calcomp GTCO Roll upDigitizer
First thing to do is select S01 on your superset menu.The menu located on the lower left hand side of your RUD II. Take your stylus or cursor and select "S" then "0" then "1", this puts the digitizer in the correct settings to work with the drivers. You should hear four (4) sucess beeps when this is done. Take your stylus or puck and move it around on the digitizer. If it is communicating, the pointer on your computer desktop will move.
If this doesn't work, uninstall the GTCO drivers and reinstall them. If this doesn't work then you will have to call GTCO Tech support for help, they may be a problem with the digitizer.
Posted on May 15, 2009
caroldon
  • 17130 Answers
SOURCE: I have a garment CAD
Hence please mention the fault that is seen with the CADin coonnection. We at fixya can help only with more clarity on the question.
Posted on Sep 25, 2010
SOURCE: GTCO CalComp Drawing Board II
I think that the II and the III is the same.
(sorry for my bad english)
I have the II and I have the user's manual, but my scanner it's death...
Posted on Oct 30, 2010
SOURCE: The GTCO digitizer roll up board was folded and now has a crease.
No, the lines in the Roll-Up are probably broken.
If you send it to GTC for repair, they should give you a discount on a new one.
Posted on Nov 27, 2010
SOURCE: I HAVE AN OLDER MODEL
You can try the Tech Support section at GTCO.COM or vtablet.com,on vtablet the drivers aren't free and will have to be purchased.
How do I reset the digitizer?
There is no reset for this Digitizer, it there are dead spots on the grid, the digitizer is no good.
Feb 18, 2014 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
How to set up mouse on paydirt software, currently working in reverse
This could be a problem in Paydirt or the setup of the digitizer.
The Roll-Up II and Roll-Up III digitizer would allow you to change the orientation from one side to another,check this first.
The 0,0 point should be at the left hand side of the Digitizer where the metal housing and connections are.
There is a selection on the menu to change this,it looks like a double-headed arrow.
Sep 20, 2011 | GTCO Corded 16 Button Cursor with 3 meter...
I have a garment CAD of China, my garment CAD of China can connect to GTCO Roll-Up Digitizer, 30/36"
Sep 25, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I HAVE AN OLDER MODEL GTCO ROLLUP II DIGITIZER (3036R), BUT CANNOT LOCATE DRIVER DISK(S)---- WHAT IS THE BEST WAY TO OBTAIN A DISK? B.C.
Aug 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I have the stand-alone system with the LCD screen,
These original Roll-Up I Digitizers didn't use a power supply,all of the power came through the Com port connection.
The Roll-Up II used a 9 volt center positive power adapter.
May 14, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Jan 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Looking for a manual for a 3648 III roll up
Go to www.gtco.com, select Tech Support/Large format Digitizers,then select GTCO Brand on the bottom of the screen, then select documentation and a PDF file can be downloaded.
Dec 17, 2009 | GTCO Roll-Up III Digitizer Graphic Tablet
Go to the search on your computer and find your tabletworks. Open tablet works and go to mapping. Click pick. Locate your mouse pad on the digitzer pad. Click Apply. This worked for me.
Mar 29, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Wont recognize gtco digitizer on start up
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Feb 06, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Computers & Internet Logo
439 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
