Question about Yamaha P4500 Power Amplifier 2-Channel
When I turn it on the fuse blows up.
My yamaha P 2700 power amplifier when I turn it on the fuse blows up.
  • jason May 11, 2010
    there is a short to ground , it will need repair
    Genius:
  • 1,175 Answers
Hi..
It will need service.
I would call the music store closest to you that sells PA gear and ask who fixes theirs.
Posted on Jan 12, 2009
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
Yamaha p4500 keeps blowing both ET5AH250V fuses help?
Suspect an overload in the power section, or more likely the main amp. A semi-conductor device is now acting like it was a piece of wire. Easy to spot with an ohm meter, it will just like you have touch the test probes together! My guess it will be one or more of the things on the big heatsink that's gone.
Jan 24, 2011 | Yamaha P4500 Power Amplifier 2-Channel
The garget blows the fuse and goes off
if the fuse blowes when you swtich the power on its the power supply circuit. if the fuse blown after a short while that the Amp is on its possible that protection circuit is short
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 15, 2010 | Yamaha P-5000 Amplifier
My yamaha P7000 always lights its protection lamp whenever turn on...
The amp will require service. One or more power transistors have failed and the protect circuit keeps the power supply from blowing your speakers
Oct 12, 2010 | Yamaha P-7000 2-Channel Amplifier
Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Mar 09, 2010 | Audio Players & Recorders
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
REVERSE TERMINAL WIRE AND TO MUCH VOLTAGE 18 TO 12V AMPLIFER
The Power Mosfets may be damaged and therefore causing your power supply fuses to blow. The fuses on your amp may be higher current rating than the ones in your vehicle and that is why they are not blowing
Sep 18, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
Yamaha P-4500
Hi radek
If it is a toroidal,they have a nasty habit of going shorted turns on the primary. Is it blowing fuses? Let me know
robotek
ex In'gill ;)
Sep 12, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 Power Amplifier 2-Channel Logo
356 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
