Question about Char-Griller Grilling
Can you show how to convert the char-griller 3000 to natural gas
Can you show how to convert it
SOURCE: char griller patio pro Model 1515
You can get a PDF file off of chargriller.com I believe.
Posted on May 28, 2008
AlmostBob
  • 550 Answers
SOURCE: Char-Broil Advantage 463453306
All lpg(propane) fueled barbecues can be converted to natural gas some easier than others.
The process requires changing the tiny lpg nozzle with a larger low pressure ng nozzle,
Charbroil web site lists the kit -available parts for the grill http://www.charbroil.com/consumer/product_detail_e.aspx?ProductID=438
the gas conversion kit from half way down the page
http://www.charbroil.com/consumer/product_detail_e.aspx?ProductID=1722
for $69.99
  • SHOULD be done by a licensed person for safety & insurance reasons,
Posted on Jun 29, 2008
  • 2976 Answers
SOURCE: I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Posted on Feb 25, 2009
SOURCE: Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose). I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake). 46e03a6.jpg846ce6e.jpgb1bb7d1.jpg
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
Posted on Jan 03, 2010
ChefBarry
  • 4 Answers
SOURCE: Hello I have a Char-Broil grill model# 463268706.
Contact the company --- and get a free PDF of the original product manual. You may also be able to simply ask customer service.
Posted on Jul 12, 2010
Manual for char griller 3008 king griller
I could not locate a model 3008. Their gas grill line,starts at 3001 and then jumps to 4001. The only difference is the number of burners.
Here is a link to the 3001, which should be your grill or very similar. You can download & print the manual for future reference.
http://ftp.chargriller.com/manuals/3001_OM_12-11-07_Eng.pdf
I hope this helped you and Happy Grilling. Thanks for choosing FixYa.
Aug 08, 2011 | Char-Griller CharGriller Grillin Pro 3001...
We purchased a used Vulcan Steamer model # VSX10GC which was set up for propane. We need to convert it to Natural Gas. How do we do this and how do we get the parts
Please be careful when converting appliances form natural gas to propane. Depending on the equipment there are several changes that need to be made. You will at least have to change burner orifices and convert or replace the gas valve. Some gas valves are not convertible. What many people over look are changing the pilot orifice and on some appliances like braising pans, griddles and char broilers there is a runner tube orifice. The gas valve also needs to be adjusted to the proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Mar 11, 2011 | Vulcan Hart VSX5G Counter Convection...
Convert a frontavenue propane grill to natural
Visit CharBroil Master site, they should have that item for you. Also Lowes or even call your gas company and they either will have it or point you in the right direction
Jul 31, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a char griller grill.Iam trying to find a gas conversion kit for my 3000. Rey from phx az.
If the grill can be converted it will be labeled as duel fuel. If it is not labeled as duel fuel, then you will most likely not find a conversion kit for it.
Jan 02, 2010 | Barbeques Galore Turbo Classic 3-Burner...
My char-broil 463268706 is not getting over 300 degrees, usually only around 200 degrees. how do i get it hotter. maybe even 400 degrees? (its set up as propane)
kwiles I do not have solution for your problem but do you still have that grill? I have the same one but it is converted to natural gas now I need to convert it back to the propane gas but I have lost the orifices which I removed to convert to natural gas. Can you please help me and unscrew one of your orifices take some measurements and pictures and send it to me? my email krislizak at gmx dot com. Please help me I need those dimensions.
Thank You
Jun 30, 2009 | Char-Broil Grilling
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
for $69.99
Jun 29, 2008 | Char-Broil Advantage 463453306
Char griller patio pro Model 1515
May 04, 2008 | Char-Griller Smokin' Pro CG010
Grilling Logo
42 people viewed this question
Top Char-Griller Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Char-Griller Grilling Expert? Answer questions, earn points and help others
