Question about Exercise & Fitness
Reebok v8.90 stopped working - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
LUBE the deck belt, Maybe you have WORN deck belt.
2)lube THE ROLLERS BEARING TOO
2a) test the drive belt motor, for worn, or tight a little by 1/4"
3) Test the input voltage motor, if there are , the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. replace
God bless ou
Posted on Nov 27, 2012
Why does my reebok 8400c treadmill stop after a minute or two? The control panel works, but the tread will stop. I can start it manually, but it stops again after 1 or 2 minutes.
You have to check the speed sensor potion. Try to align the speed sensor or check is there is any dust accumulate on speed sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 27, 2016 | Reebok Exercise & Fitness
Treadmill error code
see the video and proceed according. Of course you must lube the rollers bearing front and back.
God bless you
Sep 18, 2013 | Reebok Exercise & Fitness
Reebok rx2.0 console stopped working
Hi I'm having same prob. Did you ever get solution
Feb 25, 2013 | Reebok Indoor Trainer RX 2.0 Upright Bike...
Reebok edge rower display console keeps reading 'stop'. only works if unplug adapter undereneath rower but only works for few seconds before returning to 'stop' ???
Welcome to FixYa.
If the console has a battery, most likely it is worn out already. You need to replace the battery. Some rower consoles does not easily expose the battery. You have to open it with screw drivers.
Thank you for using FixYa.
Sep 30, 2011 | Reebok New York Giants Eli Manning Jersey
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Mar 01, 2010 | Reebok 8050 ES Treadmill
Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Nov 25, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
