Question about Echo Garden
How to install an ignition coil in blower echo pb 400e
  • 666 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
panilling9
  • 284 Answers
SOURCE: what are the specs on an Echo blower pb 400e? I
http://www.echo-usa.com/pdf/documentation/PB400ET1e_100195.p
Posted on Jun 17, 2009
#1 Taper
  • 1041 Answers
SOURCE: ho spark on a pb 403t backpack blower
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
Posted on Nov 30, 2009
radar001
  • 1051 Answers
SOURCE: need oil/gas ratio for Echo back pack lblower -
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
Posted on Mar 31, 2010
rycgl
  • 1545 Answers
SOURCE: air cap on ignition module Echo PB-413H blower
The air-gap between the ignition coil module and the magnets of the flywheel is a close tolerance. It is adjusted to about .010"-.012". This is approximately the same as the thickness of a standard size business card. I double the cover and let the magnets on the flywheel (lined up with the coil legs) pull it in tight 9compressing the paper card) and then tighten the adjustment screws. The screws have been known to vibrate loose and the gap would be lost. You can use threadlocker on the screws (optional) or just tighten them down well. Too large an air-gap is bad, but the closer the air-gap, the stronger the spark.
Posted on Dec 27, 2010
How do I test an ignition module
you truly can't. they have some tests but they're not reliable because we cannot duplicate hot running conditions. If you have no spark, suspect a bad coil.
p.s. most of the Echo line of hand held equipment come with a lifetime warranty on the ignition coil. but there is always a catch. go find Echo's homepage and check for yourself.
Oct 19, 2014 | Echo Garden
What's mis ratio for ECHO PB-400E blower
Two very good answers, if you go to use the 50:1 ratio you will probably not be wrong most new stuff mixes with the 50:1 ratio these days if your not comfortable mixing the gas, Menards has premixed can for sale, as do most of the big box stores. Very good for novice mixers who don't want to keep alot of fuel around and let it go bad. Great alternative to mixing!
Jun 21, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Need parts for echo pb400
Part # for this filter is ( 13031000760 ).
Oct 16, 2013 | Echo Air Filter For Pb 400e Back Pack...
Not getting fire to plug,replaced ignition still no spark,echo pb-400e
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
Jul 29, 2011 | Echo Inc. 25.4 CC Backpack Blower
Need oil/gas ratio for Echo back pack lblower - model PB-400E
Mar 31, 2010 | ECHO, Inc. PB-251C Handheld Blower
Echo PB 400e backpack blower "Adjust"?
Hi. Does anyone know what year my Echo pb 400E Backpack blower is?
Sep 25, 2008 | Echo Garden
Open Questions:
Garden Logo
132 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
