PC doens't boot up HELP!
Hi AMD athlon won't boot
My Asus motherboard will not boot. I have A AMD Athlon processor and 128MB . The problem is nothing appears on the screen when I turn it on. I have checked the graphics card and concluded that is not the problem. It has to be the moterboard or CPU. When I turn the Computer on it gives power to everything, but nothing happens.
  • krishna Singh
    krishna Singh Jan 15, 2009
    hi friend
    Every thing check ....when i start cpu fan run mother board LED run
    but not boot cpu..
    plz tell me what problem it ?
    when i press power bottom it turn off......
    Problem Solver:
  • 8 Answers
There are a few things you can try, the trouble shooting doesnt necessarily have to follow in this order. Best thing I can suggest is try re-seating the processor, and if that is the only stick of RAM you are using see if you can find another to test with. If it still doesnt work after either of those, you might have to try a different processor. Granted, this is if you have those parts on hand. If you still are unable to even get a POST beep, then I would also try snatching the CMOS battery, unpluging it and then hitting the powerbutton reset the CMOS to default settings. If it still doesnt work after you get back then there, then I would snatch every removable piece of hardware from the board down to just the processor/heatsink/fan, memory, and PSU. If you get a POST beep after that, then try adding one piece of hardware at a time until you find the problem piece. If it still doesnt work then there is a pretty good chance that the board is dead.
Posted on Jan 10, 2009
  • Archangel357 Jan 15, 2009
    I honestly cannot say with 100% certainty without being there; however if you went through all the steps that I gave, there is a good likelihood that the board is fried. If you was not able to test with a different processor and memory there is a possibility that it could be either of those. I guess just try turning it on with nothing but the processor and fan attached and not anything else. If you still don't hear a POST beep, then take a close look at the processor. Sometimes with the AMD's when they overheat you can see some scorching on the chip itself (although I have only seen two in about eight years). If it looks clean, odds are higher that the board is fried. I have seen some fried chips over the years but there is a much greater likelihood that it is the board. As bad as it sounds all I could really suggest at this point is that if all else has failed, check newegg.com for a new board, possibably processor combo. I always hate replacing parts when I have no test parts to test with to be certian but options are narrowing as to what it can be at this point.
Is it possible that AMD Athlon II X2 (3.0ghz) processor will fit in in this ASUS A7V8X-X motherboard?
hello there,
  • Socket A CPU support Type,
  • models Athlon, Duron, Athlon XP
  • The AMD Athlon II X2 is a Socket AM3, sorry to tell you that this motherboard and CPU will not work together correctly. New motherboards are always fun
Jan 27, 2011 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
Aug 04, 2010 | ASUS M2N-MX Motherboard
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Will a amd athlon 3000+ fit in a asus km400
you need to find out what socket the amd athlon 3000 is and what the socket for the asus is go to amd's site and then the asus site they can help big time..=)
Nov 01, 2009 | Computers & Internet
I have lost my motherboard driver CD( AMD Athlon(tm)xp 2000+ 1.68 GHz,),from where i can download?. plz help?
If your motherboard is ASUS then you can go directly to www.asus.com and search for the k8mv motherboard drivers or
if its a MSI board the go to www.msi.com
May 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
