Replace receiver board asr 70 T seies arlec air con
3 Suggested Answers
  • 884 Answers
SOURCE: Replace Receiver Board on Arlec Air Conditioner
Are you sure it's the receiver board? If it's cooling and switching on and off, I would suspect the 4way valve or coil, not a control circuit. Of course, you may have already tested this and found no power to the valve coil, in which case I apologise and suggest you try on line to get a manual. Good luck!
Posted on May 17, 2012
kevin_getz
  • 1031 Answers
SOURCE: Require Manual for Arlec Air Conditioner ARS70 to replace Receiver Board
www.manualsonline.com or www.searspartsdirect.com
Posted on May 18, 2012
When my TV have no logo when i turn it on. I changed the power board and the main board already. The problem still there. I bought a bad main board? Or I need to change my T con board too?
T con board responsible for final picture on screen of set. And visible distortions are caused by it. The inverter board powers the back lighting so you can see the picture. If screen is totally black that could be the issue.
Oct 28, 2015 | Vizio E701I-A3 70" LED TV 1920x1080, 120...
May 17, 2012 | Heating & Cooling
A circle with a triangle sign appears on the dashboard appears
ASR - Acceleration Skid Control system.
When ASR warning light blinking the system is activated itself for car acceleration skid control.
For today's typical high-torque engines, traction control (ASR) can increase both comfort and safety, particularly when driving on slippery roads or surfaces offering differing levels of grip. Traction control permits smooth starting and acceleration through the full speed range without wheel-spin or fishtailing.
ASR only operates in conjunction with the electronic accelerator (E-gas) and uses components of the anti-lock braking system (ABS). If one wheel suddenly begins to rotate faster than the others (slip), ASR intervenes in the engine management system and reduces power until the wheel stops spinning.
The ASR system represents a further contribution to active safety as it maintains vehicle traction and directional stability throughout the acceleration phase at any speed. In addition, it reduces tyre wear. Activation of the ASR system is indicated by a flashing indicator lamp in the instrument cluster.
The ESP system means the Electronic Stability Program. If the ESP lights on the dashboard permanently the ESP system is faulty. You must access the ESP Electronic Control Unit (ECU) memory for pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car. Then you will be full informed about bad pieces (e.g.: front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ESP ECU, in other words reset the ESP system and turn off the warning lamp on dashboard.
Sep 16, 2011 | 1999 Volkswagen Passat
Bateria sem pegar carga. no carregador leed vermelho piscando
o que exatamente acontece .. e agrada ... se você quiser uma tentativa de resposta completa em inglês..
todo que aparece aqui está que você usou está durante seis mês e ... aconteceu repentinamente... Nada mais..
Jun 28, 2010 | ASUS Eee PC 1000H Laptop
Air con not cooling
If the car's more than a few years old, it probably just needs something as simple as an AC recharge. This runs around $70 at most reputable shops, or there are kits to do it yourself for less money. It's fairly dangerous stuff to deal with, and usually best left to the professionals.
Apr 13, 2009 | Volkswagen Beetle Cars & Trucks
The light 'ASR' on dash board was on
you will need to replace the ASR actuator assembly is this happens again, very expensive fix and all to common a problem
Mar 22, 2009 | 1998 Mercedes-Benz SL-Class
Air conditioning - Mitsubishi diamante sei 1998
Yes. A Recharge on the System will Fix this Issue. Please Rate My Response! Thanks!
Feb 01, 2009 | 1998 Mitsubishi Diamante
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
