Question about Pride Mobility Products Health & Beauty
Quantum 610 power chair error message 192 motor 1 not connected
2 Suggested Answers
  • 32 Answers
SOURCE: Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
Posted on Jul 13, 2009
I have quantum pride 610 chair when l power on it show me an error . The errorcode#36 release joystick .please l want some help
i think you will have to ring your support team and carers asap
get someone to test the power control module under the seat or the joystick controller
the batteries must be charged to get the error message
this the quantum pride 610 user manuals
http://www.pridemobility.com.au/default/assets/pdf/Owners_Manuals/US_Q610_Aug13.pdf
Apr 30, 2016 | Pride Health & Beauty
When I go To move the chair comes up with error 107. , charger inhibit . I disconnected the charger. What can I do next
after do a test restart the chair. make sure both freewheel levers are locked in drive mode (hard to push), restart, make sure your connections are good, to the motors and brakes. what kind of Joystick is this?
Apr 07, 2016 | Quantum 6000 Power Chair - Used Electric...
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Im gettiing a "brake disconnected error code 204" how do I fix it?
On a power chair I would check all plug connections on motors. Check resistance of brake coils and compare with each brake. If you have the error code I would check the manual that comes with the diagnostic box.
May 08, 2015 | Quantum 6000 Power Chair - Used Electric...
Wheel chair will not turn left
Check for intermittent left motor wire connectivity at 4-pin connectors red and black wires. This is a common issue with this model: motor power wires break inside the wires insulation causing jerking and eventual stopping of motor. Motor resistance should read between 1 and 3 ohms. If this is the issue have the motor rebuilt.
Mar 14, 2014 | Quantum 614 HD Power Chair - Used Electric...
Charger inhibit error
Hello Debbie Waters,if you contact a Wheelchair/Scooter Repair Shop.Give them what you see as to (WHY) & ask for a price on the Part.I hope this has helped,Colin.
Jan 16, 2014 | Quantum 6000 Power Chair - Used Electric...
Quantum 610 error #107 Charger Inhibit
I just had same code. I took off rear cover and unplugged a rubber cap at the end of a long skinny group of a few wires. looks like a charging wire kinda. and unplugged the main plug. I did not unplug the two larger battery plugs. when I plugged them back in firmly everything was back to normal.
Mar 03, 2012 | Health & Beauty
Health & Beauty Logo
59 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
