Question about Hasselblad 503CXI Medium Format Camera
Whats the diff between the 503cw and the 503cxi?
I have recently decided to go Hasselbald. I will need to shoot digital and I have been told the 503cw is the body for me. What is the difference between between the 503cw and the 503cxi? The cxi seems to be more ava. and at at better price.
  • 36 Answers
The only real difference between the two is that the 503cxi have a too short, vignetting, mirror. The 503cw have a long, non-vignetting mirror. The vignetting is only noticeable in the viewfinder, and when using lenses 150mm or longer.
Both bodies will accept winder CW, and both have TTL flash metering.
/Chris
Posted on Jan 19, 2009
How do i remove the rear diff on a viking mt830 ride on mower
Go to you tube on the line removal transaxle viking mt830
Sep 13, 2014 | Garden
How do you turn o and off flash
Your camera has 4 modes flash function : 1; Flash Off ( flash will Off in any shoot) 2. Flash Fill in ( flash always On) 3. Auto Flash (Camera decided flash) 4. Red Eye reduction flash ( Camera decide flash).
You can set your flash base on your need.
Nov 29, 2010 | Polaroid i531 Digital Camera
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
May 07, 2010 | Lincoln Conveyor Oven - 1132-000-A
The whole car vibrated and had to remove the draft shaft. Whats the effect if i just use the Honda CRV without the shaft as 2 wheel drive. I am told the diff mounting is broken. What is its function. whats...
it is safe to drive the vehicle with front drive shaft only. if there is a mount that is broken, REPLACE IT! there is a danger if that is broken. if the tech already has everything, might as well get it done and enjoy your vehicle. cheers.
Nov 30, 2009 | 1998 Honda CR-V
I had problems with my 1D Mii on a recent shoot.
Run the SENSOR Cleaning option to see if that fixes the problem
Jul 29, 2009 | Canon EOS-1D Mark II Digital Camera
DISPLAY WINDW DAMAGED
Hi i can deliver you a new one, i have a shop and sell LCD assy for all types Canon and several diff brands.
Regards,
Rob
Feb 10, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
503CW with leaf back
Can you shoot rear curtain flash modes?
If not, try this:
Advance the camera.
Open up the shutter(set mirror lock-up). You'll have to remove the Winder CW to do this.
Push black Tap up to open up the shutter. Don't worry, lens is still closed.
You'll not see anything from the viewfinder, just black.
Trip the shutter button.
Now, check the images.
What do you get?
Try shooting under one second in low light.
Battery is new and not over 5 years old?
71% related to digital back
24% related to battery
4% related to electronic/mech problems & human errors
1% related to camera's back to digital back
atdlee@netzero.com
Feb 25, 2008 | Hasselblad 503CW Medium Format Camera
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Hasselblad 503CXI Medium Format Camera Logo
493 people viewed this question
Top Hasselblad Photography Experts
pontelemon
pontelemon
Tony
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
