Question about Swisher 60" 13 Hp Trailmower #T1360h
How to change oil on a swisher rough cut 44
There is a yellow cap by the drain hole,whats that all about?does that need to be taken off?
What size is deck belt for swisher trail behind 44'' modelt11544
Swisher 4220 74-Inch Belt - Fits select Swisher 44-in, 42-in and 22-in Mowers
Jun 22, 2015 | Swisher Garden
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Jun 28, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
Oct 24, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
44 swisher
THAY SHOULD MOOVE THE ONE THAT WONT MOVE NEEDS BEARINGS
Apr 27, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
Should the 1" hole on the side of the drain pan be connected to a drain line or should it be capped off like my A/C installer did?
Hello, there should be 2 holes in the drain pan, one is for a drain connection and the other is a overflow and should be capped off.
May 10, 2012 | Ruud Heating & Cooling
I got alot of vibration when i engage the blades on my 44 inc swisher rough cutter
I had the same problem twice. The first time happened when the blades were not swinging freely because they got gummed up with grass. So make sure your blades pivot easily.
The second time happened when the nuts came loose from the blade driver (the part underneath the deck that the large bolt goes through to hold on the blade assembly). I had taken the Swisher to a small engine repair place for servicing. They removed the blade assembly to sharpen the blades while it was there but put the old lock nuts back on without using any Locktight, so the nuts started to come off while I was cutting. Unfortunately, I did not notice this until after the blade driver got very loose and then got reamed out by the wobbling of the large blade assembly bolt. I had to replace the blade driver and its bolts and nuts.
May 09, 2012 | Swisher 44-Inch 12.5 HP Trailcutter...
Swisher 60" 13 Hp Trailmower #T1360h Logo
288 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
