Question about Vtech V.reader Animated E-book System
V reader won't turn on
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
My Ematic 7 4g wifi ebook reader can't conect to
just go to network setting and turn ON WiFi first, then make a search for the availebel networks
Nov 14, 2012 | Computers & Internet
How do you clear codes for 2004 saturn ion
Clear the codes AFTER a repair was made & the light
stayed on ?
I would purchase an inexpensive $60.00 code reader &
use that.
If you start disconnecting batteries on every vehicle you
do or will own,then bad things happen.
The radio won't work,the car won't start,etc
If you have service manuals to learn your vehicles systems,
then you can eventually know what the results will be
Again,if you fixed nothing,then the light is going to stay on
or come back
Sep 18, 2012 | 2002 Dodge Dakota Club Cab
How can i read the check engine codes on a 2000 dodge caravan 3.3l v6 without a code reader
No Code Reader or Scan Tool ,was OBD1 Vehicles, from
1983 thru 1995
1996 thru 2013, you need a code reader & keep in mind there
about 900 codes on any veh & a code reader will only see Generic
ones, those being PO Codes
You need a professional scan tool or note book software to access
most of the systems
Also you can have big problems that the codes don't lead you to
or help you.
A code reader is a must for at home & are only about $60.00
BUT--you really need hundreds of dollars in factory service &
mostly diagnostic manuasl or you can keep the hood closed
If you don't continually educate yoursel,f you won't be able to
do a thing on todays technology.
Helm.Com has your maunals
I have purchased them for every veh since 1965 some 47 yrs
Jul 31, 2012 | 2000 Dodge Caravan
'Service Traction' indicator comes on, car stalls, won't restart. What's happening here?
Someone will need to scan the body computer for trouble codes to proceed. A simple code reader may not access the body computer.
Jul 08, 2012 | Cars & Trucks
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
Lock won't work
Change your battery & reprogram your lock. Follow this link.
Give this a moment to load:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
May 17, 2012 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Vtech V.reader Animated E-book System Logo
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
