Question about Sewing Machines
Juno janome 3434d flocklock stitch
How to flatlock on a 3434d juno janome, use upper lopper and right needle and it did not work. what wrong?
jessee007
  • 310 Answers
SOURCE: loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
Posted on Jan 16, 2008
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Posted on Mar 15, 2009
kent581
  • 87 Answers
SOURCE: Right needle skipping stitches Janome 4623LE
if you adjust that setting, check that the needle goes into the needle plate the exact same distance front to back on both the right and left side. Also, be careful not to change the height when changing the twist.
Posted on Mar 23, 2009
  • 55 Answers
SOURCE: my janome harmony 9102D serger I think is out of
i suggest you get a tech to re-time your machine. timing is complex on an overlocker and if not done correctly you will probably break a looper.
scott.
Posted on Jul 27, 2009
I am looking for the instruction manual of the janome v 74088 619
Search the internet for:
Make + Model + the word "Manual"
Feb 29, 2016 | Janome Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Janome Juno 3434d wont make a chain
If it was hitting before you stopped, it's likely that the looper either got bent or was knocked out of time. I would take it in for repair.
Dec 23, 2012 | Sewing Machines
My Juno janome serger 3434d upper looper and lower looper keep jamming into each other.
it sounds like the serger needs to be checked to see if it's out of
time, at a sewing machine shop
Sep 23, 2012 | Janome 6019QC Mechanical Sewing Machine
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
I have a juno by janome 3434d serger. when i ruffle, the first thread keeps breaking and it will not ruffle correctly. what can i do?
Whenever I've had an issue with threads breaking, it's usually the tension or it's not threaded right. You probably have the first thread lapping over one of the bottom threads it shouldn't be lapped over. I would suggest you put all of your tensions back at factory level, pull out all the threads and rethread the whole thing. Thread the two bottom ones first without moving the handwheel. (Make sure the handwheel has the two top needle in the up position. When you thread this machine, you must not have to turn the handwheel. If you do, you change something.) Then thread the top needles. After that hold all four threads and make a string. Test on the same type of fabric as what you're working with. Adjust tension as needed. HTH
SharonH
Aug 31, 2010 | Janome Sewing Machines
I adjusted my foot tension and now can't gather on my Juno Janome
A lovely woman has a little sewing blog online that is incredibly helpful. Wow, a tiny little adjustment that wasn't included in my manuel and presto.....perfect gathering.
Nov 16, 2008 | Sewing Machines
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
