Back to:
Tags:
GE Monogram ZISS480DRSS Stainless Steel
Water dispenser suddenly started spewing out water... (by 6 users)
posted by FlashFlood on Jun 05, 2007
Water dispenser suddenly started spewing out water without being touched! Luckily I was in kitchen at the time. I hit buttons but it was stuck ON(wtaer/cubes/crushed ice). I had to run down to crawlspace an shut off supply line. Then I turned ice maker off and set fridge to lock.
I am worried that even if I reset the machine and it works, what if it happens again when noone is home?!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by chris938, posted on Sep 30, 2008
Disconnected the ice dispenser cable harness above the freezer door to stop the motor. Is it possible to locate a mother board to replace without calling a technician?
Comment by Guest, posted on May 04, 2008
We have a ZISS420DR1SS and had the spontaneous spewing of water from the door dispenser occur today. Fortunately, the basement below the affected area is unfinished, but we expect problems with our kitchen hardwood flooring.
We're thinking this problem was somehow caused by the fixing of several other problems in the past two weeks. Since the unit was freezing food in the refrigerator portion, GE service replaced the system board. Since the ice maker's water level was too high, ice cubes were sticking to each other and clogging the ice dispenser. GE replaced the ice dispenser too.
Unless GE comes back with a really good story about how this issue won't happen again, we can't afford to keep the unit and live with the constant threat of a flooded home. So we're faced with fixing our flooring (if it doesn't return to normal) AND buying a non-GE replacement. I really hope that we can get a refund from GE and coverage of our floor repair.
(I should note that we had a similar, but older counter depth monogram unit for 5 years in our previous home and didn't have any of these issues. However, given the severity of water flooding, there is no way that I would purchase another GE unit.)
Comment by arnellim, posted on Apr 29, 2008
This just happened to me with my Monogram Fridge. Water was everywhere. It stopped, I cleaned it up, then 5 minutes later, it happened again. I have hardwood in the kitchen. It would have been COMPLETELY ruined if I wasn't home. The fridge is only 2.5 years old. I'm going to call GE service tomorrow, but this is unacceptable for a $7K fridge. I need to start researching more for other such stories. I'd like to start collecting names, emails and send a formal letter to their Monogram division. Please email me with your name/email/story/city. You'd think there would be a failsafe to prevent this.
Comment by Guest, posted on Jan 05, 2008
ice dispenser suddenly started spewing ice out, then water out . If you touched button for ice it started throwing ice out on the floor everywhere, then water.
Comment by gbuck, posted on Dec 05, 2007
This has happened twice to my unit. The first time, no one was home so the motor continued to run until the board burned up. The second time, I was watching TV and all the sudden the ice maker came on and dumped the entire ice bin on the kitchen floor. And when the ice bin was empty, the motor continued to run. Opening the door did not turn it off. Luckily I remembered the service tech had shown me where in the unit to disconnect the power to the ice maker and controller. I'm not at all happy about this.
Best Solution
posted on Aug 26, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This has happened to us twice. The first time the motherboard was replaced and it just happened again today. I'm furious that this is the 4th breakdown in a year on a refrigerator that costs approx $7000. I intend to demand a refund as I can't feel safe leaving the house with this refrigerator in place. Replacing the motherboard will fix the problem temporarily but these boards fail regularly by all accounts. If it happens again, opening the door will stop the water/ice immediately while you figure out your next step. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Water dispenser suddenly started spewing out water without being touched!:
I don't want to Accept this solution
Solution #2
Not Rated (0)
chris938
Rating: 0%, 0 votes
I also had ice dispensing al by itself. I was able to stop this by disconnecting the wire harness directly above the freezer door. I would like to find a schematic for this. Does anyone know where I can find one? Also, who knows where to get a new mother board?
Thank You!
Solution #3
posted on Sep 08, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
We have a Monogram and had the spontaneous spewing today as well. We need a good class action attorney.
We also had spontaneous shut down problems which GE finally repaired after 3 motherboard replacements.
What a piece of junk! russ@rbace.com
Thank You!
Solution #4
Not Rated (0)
ckamps
Rating: 0%, 0 votes
Thank You!
Can you Help with these Refrigerators problems?
We have a GE Monogram ZISS480DMCS ss side-by-side...
Just suddenly stopped making ice. It's turned on, makes...
is there
Trying to remove grid in order to clean coils. Took out...
I have a ge monogram side by side fridge. Today, all ofa...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
