Question about Tecnik TKL9290 Front Load Washer / Dryer
Non-performing softener outlet
My machine's softener outlet is not working. Softener liquid remains in outlet after full automated wash. Any idea why this is the case and suggestions for solutions?
  • Tecnik Master
  • 3,463 Answers
More than likely a blockage in the dispenser drawer,remove drawer, and thoroughly clean every part of it, particularly the condioner compartment and any removable parts in it, also clean any residue of powder or conditioner in the dispenser compartment..
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
Fabric softener holds water
The softener dispenser gets flushed at the end of the wash cycle to prevent clogging.
Aug 28, 2017 | Washing Machines
Samsung washer softener
2 possible reasons for your issue, you might be filling the softener compartment too full, or possible pushing the tray in too forcefully causing the siphon action to occur which empties the compartment. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
The softener container doesn't empty, remains full after the run
Not familiar with that model but usually the cause is the dispensor is clogged up. Remove and clean.
www.appliancehelponline.com
Feb 26, 2010 | AEG Washing Machines
Nexxt 500 washer - fabric softener tray fills with water and doesn't drain. I have not used liquid fabric softener in this machine. It is 16mo old. What do I do to stop this?
There is suppose to be an outlet that opens up at the same time water enters ( to flush out softener). That outlet is either stuck shut or the wire fell off (I believe this is a little solenoid plunger with a wire attached). It is common for wires to come loose from the vibrations of the machine
Aug 20, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
New LG 10480 - softener liquid remains in the
Appeared to be a constricted water input hose - pulled the machine out from under counter and re-routed input and drainage hoses. Seems to be ok now.
Aug 18, 2009 | LG Washing Machines
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
