Question about Emerson Microwave Ovens
Replacing a bulb on Emerson Microwave Oven MW1161SB
Light does not work inside Emerson Microwave Oven
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
  • 89 Answers
SOURCE: Emerson microwave light out
There is a way but.... you will have to remove outer cover generally held on with screws at rear and under microwave be sure the oven is unplugged and when you take cover off there is a capacitor in there thats holds a charge stored even when oven is unplugged so dont touch nothing except the light bulb would prefer if you dont have much electrical experience to take to repair shop or have someone do it who has a little electrical knowledge hope this helps
Posted on Sep 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
Where is the light bulb in a emerson mw8115
It is inside the outer shell of the microwave, remove the outer shell to access the bulb, the srews that hold it on are on the back of the oven. You will need to disconnect power of course and do the work in an area that alloes you access to rear of the oven.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 18, 2012 | Emerson Black Microwave Oven
Mw1161sb suffix a emerson microwave not heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
[]\\\\\\\\\\\\\\0
Dec 18, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I need a manual for MW1161SB suffix A 120V
mcdevito75 here, You should be able to contact Emerson online or check with any store selling Emerson microwave ovens for contact info.
Jul 09, 2010 | Emerson Microwave Ovens
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
No light inside of microwave
I hape that's .9 cubic feet, cause it it is 9 cubic feet that is on heckuva microwave!!!. Anyways, did the light once work? or are you curious if it supposed to have a light. If the light once worked, replace the bulb...
Mar 03, 2009 | Emerson Black Microwave Oven
Light bulb going out
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
559 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
