Question about Whirlpool Dishwashers
Whirlpool dishwasher GU940 series, normal light keeps blinking
huuum
  • 750 Answers
SOURCE: whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 10, 2009
SOURCE: My Whirlpool quiet wash plus 940 series is stuck on "lock out"
Same problem and I was about to call for service. Opened the dishwasher to get the model number and noticed a sticker stating to hold down the Heated Dry button for 5 seconds to clear the lock light. Worked for me!
Posted on Aug 23, 2009
SOURCE: **My dishwasher normal light keeps blinking**
I have the same problem. I have tried turning off the breaker and the door seems to be locking, but still won't work. Any other suggestions?
Posted on Dec 13, 2009
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I have a quiet partner 3 dishwasher it keeps blinking normal and I can't get it to start. Help can't find book.
If a whilpool dishwasher starts blinking one of the lights all the time the touch pad is stuck. The key that goes with that light is not working properly. The only fix for that is to replace the control panel.
May 19, 2008 | Whirlpool Dishwashers
Dishwasher blinking light
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen to heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that you will fill the dishwasher with hot water instead of the cool water that is normally in the lines before the hot water from the hot water tank heats the line. This should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
PS Your dishwasher is actually manufactured by Whirlpool.
Feb 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
