Question about Garden
John deere 3320 code 65 - Garden
braintrust
  • 62 Answers
SOURCE: my 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Posted on Oct 27, 2009
wireguy212
  • 1627 Answers
SOURCE: error code 74 on john deere 3320 tractor
Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty.
Posted on Dec 02, 2009
wireguy212
  • 1627 Answers
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
Posted on Jan 02, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere 3320 starts up,engine runs,pto works
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Posted on Feb 17, 2010
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
John deere 3320 error code 63
You just go to the link I attached I'm sure you will get the solution of your problem.
John deere 3320
May 29, 2017 | John Deere Garden
John Deere 3320 error codes
John deere 3320
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Error code 68 on a 3320 john deere
a code 68 0nthe dash display means the relay that supplies power to the engine controls has Not cycled correctly, most all the new stuff in the first two seconds of turning the key tests more stuff than a human could dream of , this is one of them , seems the computer turns on/off this relay so fast its looking for it to cycle ,before it turns it back on to start the engine , Jd calls it a "Hold In " relay , this problem is gonna require a Jd scan tool to figure out whats wrong , but do try and remove the relay and give it a few taps on your palm to see if anything s loose inside of it , silly as it sounds but relays do stick , but I feel this ones electrical
this fault should lock out the starter the book says
Feb 16, 2015 | John Deere Garden
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Where is the hood release for the 3320 John deere tractor?
Jan 02, 2010 | John Deere 3010,3020 Tractor Basic...
Error code 74 on john deere 3320 tractor
Nov 25, 2009 | John Deere 3010,3020 Tractor Basic...
My 3320 john deere jerks and also shuts off the
Oct 10, 2009 | Garden
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
