Question about Sharp 56DR650 Television
Tv wont turn on. error code 32 light problem failure
I get error code 32 on my tv. i took out the color wheel and cleaned it and still nothing is it just the bulb? i can get an entire new light engine for 100 used i just have to replace the color wheel. i would be able to use mine then to make it work. but what should i do to fix this problem?
  • fraige06 Jan 10, 2009
    sharp 56dr650
  • 133 Answers
What is the Model number?
Posted on Jan 10, 2009
No power to set no led lights blinking
Could be an open internal fuse or power supply failure
Sep 06, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Hello my name is Devin, I have a wd-65735 model and I just purchased it off of a friend and braught it home. He had told us from laying it on its side while bringing it home it said in the guide to let it...
Caveat: I am not a tech, I just read through the Mitsubishi service manual, and have worked on different model TV that I have owned (older model of this one) I am a little unclear on the second set of lights but I think the combination *may* indicate that the lamp fan is not starting (there are two fans though), if the blinking red is the status light. It is possible the connector for that got jostled during the trip, something fell into it from being on the side (wire or loose something) and is blocking it from spinning now, or a module unseated a bit,and is loose, or the lamp is no longer seated correctly (though the lamp light does not appear to be on) or none of these. :) These are just guesses.
Be careful if you open it up, due to potential for shock. Wear gloves, and power it down first (then unplug). Reseat any fan connectors.
Google: I used "wd-65735 status lights" to find a service pdf , it's for V39 chassis (several models)
From page 24 of Service Manual :
3. Error Code Operational Check Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Opera- tional Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
  • ThenumberofflashesindicatesthevalueoftheMSD(tensdigit)oftheErrorCode.
  • Theflashingthenpausesforapproximately1/2second.
  • TheLEDthenflashesindicatingthevalueoftheLSD(onesdigit)oftheErrorCode.
  • The Error Code is repeated a total of 5 times. Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
Page 24
MODELS: WD-60735 / WD-60C8 / WD-65735 / WD-65736 / WD-65835 / WD-65C8 / WD-73735 / WD-73736 / WD-73835 / WD-73C8
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
ERROR CODES page25image3968
Code
Description
Most Likely Cause
12
No Error found
17
Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
Engine Failure
18
Engine will not accept data (ASIC-READY signal from Engine is not detected).
Loss of 12V from PWB-POWER (Loose PE or PE2 connector); Bad Color Wheel (Loose J6 or J7 connector); Engine Failure
32
Lamp cover is open.
Lamp Cover Switch; Loose CD connector
34
Lamp turns Off while the TV is playing. Lamp failure
(Lamp Enable signal from engine is lost)
Lamp Cartridge Failure
36
Exhaust Fan failed.
Loose J4 connector
37
Engine (DMD) fan failed.
Loose J5 connector
38
Lamp temperature abnormally high.
Poor Air Circulation; Loose J3 connector
39
DMD temperature abnormally high.
41
Standby Supply Short is detected. (5VS or 3.3VS)
PWB-MAIN Failure
42
Sirocco fan failed (Lamp fan).
Loose J8 connector
44
Check for disconnected DVI cable between PWB-DM and Engine. (Engine pulls DVI pin 14 Low)
DVI Cable unplugged
48
PON-SHORT 3.3V switched supply short
PWB-MAIN Failure
57
Ballast communication problem (ballast to chassis)
Loss of 340V from PWB-POWER (PL or CJ1 connector); Loose FB or CJ3 connector; Ballast Failure
61
No LAMP-EN output from the engine to the ballast
66
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp) (Lamp-Enable goes to DM but not to Ballast)
Loose CJ4 connector;
No Lamp Inserted;
HV connection or lead wire to lamp; Lamp Cartridge Failure
Code 34(1) - Lamp Enable is generated to activate the Lamp
Code 57(2) - Lamp Enable is generated during P-ON sequence, but no Lamplit signal is received from the Ballast. Code61(3) -NoLampEnableisreceivedattheDMandBallast.
Code 66 (4) - Lamp enable is received at the DM but not at the Ballast.
4. Error Code Log
The Error Code Log - may be helpful to retrieve the code for an error the occurred in the past. To access the Error Code Log: Press <MENU> <3-5-6-4>
Oct 27, 2014 | Televison & Video
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Jul 10, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
The stand-by/timer light on the front panel is flashing red...and the TV will not turn on...I'm assuming they are related
the set gose to standby due to internal failure the number of flash shows the error code and error code can get from the internet
Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Just changed color wheel on my samsung dlp now it wont power on
First, the color wheel's 4 pin, copper connector which plugs into the DMD pcb should have the copper facing you as you look into the rear of the TV. Second, be sure you trip the lamp door switch in a closed position. Usually, you can just wrap the wht/blu wire around it, so the TV thinks the lamp door is closed. Try these and listen for the color wheel to spin up. If it does not, the lamp will NOT light. It's built that way. You may have a bad color wheel... which I have personally experienced in the past.
Mar 13, 2010 | Samsung Televison & Video
Set worked fine when turned off. Now nothing happens when pwr button is pressed. Timer light does not come on. If system reset button is pressed, pwr led flashes for 60 secs. System is still dead. Status...
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on. For parts you can find them in partstore.com shopjimmy.com or discount-merchant.com God bless.
Feb 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
I have a toshiba 62HM95.TV is trying to restart 8 times
Replace the color wheel I don't think you will any luck just cleaning it.
Jun 17, 2009 | Toshiba 52HM95 52" HDTV Projection...
Color wheel sound
FWIW
had a 46H84 given to me after "engine failure diagnosed" by Tech and $800 + estimate
Removed the engine and found the color wheel was very dirty and the shaft was not spinning well- cotton swab and denatured alcohol did the trick-
then cleaned the lens which was also dirty and while I was at it cleaned the mirror and backside of screen
Turned it on and WALLA- new set - the fan is a little noisy yet but liveable.
Total investment? 3-4 hours, 10-15 cotton swabs and a little alcohol- for the set on a rainy Sunday afternoon.
Just took a little common sense - the service manual is available online also for about $8 shows basic teardown but does not get into engine teardown which was very basic. My guess is a majority of engine failures after 4-5 years are simply in need of a good cleaning in reality
Dec 15, 2008 | Toshiba 62HM95 62" HDTV
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Picture fuzzy on dark scenes
Well I finally had the TV picked up by a Toshiba recommended repair place and they are saying that it is a bad Optical Block, also known as the Light Engine. Total for pick up, parts and repairs is $827.00. This seems ridiculous to me when brand new TVs are so much cheaper now. I don't think I will pay that much to have this one fixed.
Dec 01, 2007 | Toshiba 52HM95 52" HDTV Projection...
Sharp 56DR650 Television Logo
166 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
