Question about Lexmark X1270 All-In-One InkJet Printer
LIGHT IS BLINKING AND NOT PRINTING
WHEN I TURN ON MY LEXMARK X1250 ALL IN ONE PRINTER, A MOTOR SOUND IS HEARD(LIKE PAPER FEEDER) FOR 5-6 SECONDS AND POWER LIGHT IS CONTINUOUSLY BLINKS. ALSO THE PRINTING IS NOT HAPPENING. PLEASE SOLVE IT.
  • sehgalamitvt Jan 11, 2009
    THANX ABHINAV BUT ITS TOO LATE TO SOLVE THIS PROBLEM BY MY HAND. COZ I'VE SENT IT TO ITJ CENTRE FROM WHERE I'VE BOUGHT.
  • 22 Answers
Dear sir,
dis is the situation when ur printer is not ready.
it means either a paper is jammed inside or the gear has been jammed or the cartirage is not installed properly or the head of printer is damaged.
do reply
Abhinav
Posted on Jan 10, 2009
  • abhinav07
    abhinav07 Jan 11, 2009
    thank 4 ur reply sir,
    Abhinav
Lexmark X5270 printer green power lite continues to blink w/no other function. Can you advise? Jeff / plumeria1@clearwire.net
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
Oct 13, 2011 | Lexmark X5270 All-In-One InkJet Printer
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
Lexmark 4650 paper wont feed when printing. It starts the feed process but does not catch the paper. when it does it will take several sheets.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 20, 2011 | Lexmark X4650 InkJet Printer
Unit was working fine.It just stopped feeding the paper into the printer.Just makes a high pitched sound like it has no paper in the load shute.Thought it was the Ink.Got new ink,no luck.I don't abuse...
Sep 19, 2011 | Lexmark X2500 All-In-One Printer
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Sep 03, 2011 | Lexmark X2600 InkJet Printer
The printer was printing OK. Suddenly the paper refeed into the printer. I removed the paper but now the printer is not feeding paper. I think I may have move or disloged a sensor in the paper feeder...
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X4650 InkJet Printer
The light in the printer stays on bsay paper is jamed and theirs no paper stuck at all
Aug 22, 2011 | Lexmark X5495 Printer
Is only blinking and not printing when i try to print the usb conect successfuly to the compter but the printer is not printing the light is only blinking
The blinking light could indicate either a paper jam, communication problem between one of your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  5. Unplug and re-plug the printer into the power source to reset it.
  10. Load some paper. Try to print again.
Aug 11, 2011 | Lexmark X1150 All-In-One InkJet Printer
PAPER FEEDER SOUND AND LIGHT IS BLINKING
when you turn it on, the ink cartridge holder should be moving left to right (aligning itself). make sure the cartridges are insterted correctly and that the clasps are all the way in.
Jan 10, 2009 | Lexmark Z600 InkJet Printer
Lexmark 2500 Series printer does not work properly.
my printer does not print, but tells me i have prints pending
Sep 13, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X1270 All-In-One InkJet Printer Logo
178 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
