How to get sterio output using a Dynamode USB-SOUND7 7.1-Channel USB Sound Card.
Changing sound output from mono to sterio
BDEATH
  • 58 Answers
SOURCE: Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Posted on Sep 04, 2007
Benimur
  • 6966 Answers
SOURCE: Sound card not working ( no sound output ) mother board intel 810E
Go to Settings, Control Panel, Sound and Audio Devices, check "Place volume icon in the taskbar." In your Device Manager, pls verify that the drivers for your sound card are completely and correctly installed with no yellow or red markings. Likewise, verify that in your CMOS/BIOS settings, the onboard audio has been enabled. The sound driver/installer for an Intel CA810E has the filename 4035full.exe and uses a DOS component.
Should this not work, you might not have an Intel motherboard but one that just uses the Intel 810E chipset. Please post back with a more specific motherboard brand and model.
While it is true that the 810E chipset is by Intel, it does not necessarily mean that the motherboard entirely is by Intel. It could be by Asus, MSI, PCChips, ECS, Soltek or others. The sound therefore need not be the same for all versions of motherboards using the said chipset.
The Intel mb that uses this chipset carries the model CA810E or CA810 which uses Creative Sound Blaster* AudioPCI 128V audio solution or Crystal Semiconductor CS4297 AC '97 stereo audio codec;
The Asus CUWE-FX/RM, FlexATX or i810E uses the same Intel 810E chipset but different sound. Asus can and may use CMI, Crystal, Creative, ESS.
An ECS BKi810E(V7.3) uses the same Intel chipset but C-Media 8738 for sound.
An MSI MS-6188 uses the same chipset. It may have used an Avance-Realtek AC97 for sound.
Hope this be of some help/idea. Pls post back to confirm that you have an Intel CA810 version or by some other motherboard manufacturer.
Good luck and kind regards.
Posted on Nov 06, 2007
Philster
  • 113 Answers
SOURCE: 6 channel sound card driver for Asus A7n266VM
well, the first step is to make sure the sound drivers are installed properly. Does the device show up properly in the Device Manager? Does it show up in the Audio/Sounds configuration item in the Control Panel? If so, then:
Does any sound work, and it's just the extra channels that do not operate? If that is the case, you probably just need to run the configuration wizard. It sometimes sits in the tray, but almost always is available in the Control Panel. Once you run it you can pick what kind of speakers you have to control the various sound outputs properly for your setup.
Posted on Jan 27, 2008
  • 36 Answers
SOURCE: no sound from output 3/4
hi
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
Posted on May 24, 2008
  • 7 Answers
SOURCE: No Sound From Channel 2 on my UA 25
My laptop is problems .sound driver is uninstalled
Posted on Feb 13, 2009
Have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is mono....you plug into the channel with a mono signal cable....as long as you're panned to center on your channel strip, you would have full mono sound out...ie sound equally from both speakers. Usually you would be running your board in mono anyway.
Aug 17, 2012 | Fender Squier 4-channel Travel PA...
There are many different "listening modes" integrated on my Kenwood VR-7070 6.1 channel receiver. But i only get both front speakers to work when in "mono" mode. Is there an easy fix?
There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
Jun 10, 2010 | Kenwood VR-7070 Receiver
How to connect my HP 6730S Laptop with 7.1speaker
That model just has plain sterio output. The chassis does not accept add-on cards, so you will need to get a USB based sound card to get the better sound.
May 14, 2010 | Creative Labs Sound Blaster Live! 5.1...
I cannot get any sound output from my Acer Aspire T180 desktop PC. I changed the monitor from the original "out of the box" monitor. I have plugged in media speakers but there still is no sound output.
Sounds like a driver problem.
You should be able to get a universal Realtek driver from here.....
http://www.everydriver.com/?t=computer&m=realtek&p=download%20drivers%20for%20realtek&gclid=CIzMwe2-_ZwCFc0B4wodGHlNag
Sep 19, 2009 | Acer Aspireā„¢ T180 PC Desktop
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Jul 24, 2009 | Pioneer SX-315
Emu1616m can one output 6 mono tracks at once to a mixing desk?
sound did not provide inspite of installing motherboard softwear,my sound card is buildin,,plz solve this problem
Apr 23, 2009 | E-Mu 1616M Sound Card
Feb 12, 2009 | Edirol UA-25 External Sound System
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
