Question about Splendide Xc Washer-Dryer Ventless Platinum WDC7100XC
I need a soap dispenser tray for WDC7100xc silver
The product is silver
How do I remove the soap dispenser tray on a top loading kenmore 90 series washer 110.28974890
On my machine you remove soap side then slide softener side over to the soap side to remove
May 26, 2014 | Washing Machines
Water drains into soap dispenser; how do you prevent this? Mildew smell!
Most home improvement stores sell a washing maching cleaner product - try this or simply run the machine on the longest cycle with 2 cups of bleach added directly to the drum to eliminate the smells. Also check around the seals on the door and drum - lint and small items can collect there and mildew. For the drain problem, ensure that you washer is level or slightly leaning back ( no more than just slightly) and this could fix the problem. If not that, the pathway from the dispenser to the drum could be clogged with dried soap - try flushing it with very hot water while it is open for at least 20 mins. Fill it up, wait to drain, and do it again. You can also remove the soap dispenser tray to clean and take a look behind it with a flashlight - refer to the manual for specifics on how to remove the tray. Good luck!
Jun 29, 2012 | LG Washing Machines
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
I have a Kenmore Elite top load that is leaking some water on the floor. I had this repaired before and I know the problem that time was the liquid chlorine bleach dispenser was dirty and needed cleaning....
Usually the soap tray has a black tab at the back of the soap dispenser tray , remove the tray and take a cloth with some CLR and rub the top of the slot were the tray fits into the washing machine. If you look inside you will find that there are holes in there this is were the water come through to wash the soap out, chances are that it is starting to block the holes with either calcium or soap. Hope this helps you out.
Aug 13, 2009 | Washing Machines
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Apr 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water and soap remains in the soap tray
You need to check for blockage in dispenser, remove completely and thoroughly clean every part of it.
Other possibility is not enough water pressure to take all powder down, check water pressure, filters in hoses if fitted..
Check hose from dispenser to drum for restriction.
Plz rate my solution.
Thanks.
Dec 16, 2008 | LG WM-1485FHD Front Load Washer
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Splendide Xc Washer-Dryer Ventless Platinum WDC7100XC Logo
21 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
